C4 explosives = $20 per lb (if bought in bulk)
Ackmed
8,499
560
How much do you think I coulda gotten for this.... ? Our demo for just one mission we did. The trunk is TNT, not C4. Everything else is C4.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Nitrogen triiodine when you care to send the very best. None of those pesky detonators to bother with.
Ackmed
8,499
560
So why carry the older TNT instead of just C4?
Different needs. TNT has a much slower REF (speed in which it explodes) than C4. It's more of a pushing charge, also no splatter like C4 is prone to do. C4 is more of a cutting charge. We used the C4 mainly to blow IED's we found. We had all sorts of charges that day. We were in Afghanistan on a pretty big mission. Also had 5 APOBS, which is basically a bunch of grenades attached to a rocket used to clear a path to walk.
It's a gorilla box to whomever asked.
pcgeek11
22,391
5,004
C4 is also good for starting camp fires when it is wet outside....
Darwin333
19,946
2,330
I had never heard of APOBS until now, pretty damn groovy.
norseamd
13,990
180
They are for demining in combat operations. Basically I think they are rockets with line trailing behind, and there are explosives set apart at even distances over those lines, so when the rockets and lines come down, they blow up mines throughout a certain area. I found out about them in the same documentary that I linked Ackmed to earlier.
https://www.youtube.com/watch?v=b9Pq5JZ2Fd8
Ackmed
8,499
560
Yes, originally designed for traditional mines. We used them (and MICLIC's[1750lb of C4]) to clear a path to walk. Metal detectors were almost useless and we resorted to these and good old sickle on the end of sticks to find IED's.
In the box with the A bag inbetween, it contains the rocket.
All boxed up and read to go. Bonus points if you know what those are with it, the long green tubes.
Setup and about to deploy. You connect the two packs together, and then the rocket. There is a parachute on the end to help straighten it out. As the rocket pulls it forward, the parachute pulls it back some to keep the line straight. Otherwise it just ends up everywhere.
End results, 108 steps that should be clear.
We used all 5 that one day to help clear our objective. They're heavy as fuck, especially when you have to carry it on your back with all the rest of your gear.
edit, I can't get that one pic to rotate, oh well.
futurefields
6,470
32
there were people on social media up in arms that the police used a robot to kill this guy but i dont understand what the better alternative would have been?
