C2D System Build - any thoughts?
hudaman
This is my second time building a system. I'm going with a Core 2 Duo system - my AMD is having overheating problems, I'm not a gamer anyways. I'm more into video-editing and multimedia stuff.
Heres the parts from newegg:
Mobo:Intel Socket T (LGA 775) Intel G965 Express ATX Intel Motherboard
http://www.newegg.com/product/product.asp?item=N82E16813121052
CPU: Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model
http://www.newegg.com/product/product.asp?item=N82E16819115003
RAM: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
http://www.newegg.com/product/product.asp?item=N82E16820145034
HD: Seagate Barracuda 7200.10 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s
http://www.newegg.com/product/product.asp?item=N82E16822148140
PSU: APEVIA (ASPIRE) ATX-AS680W-BL ATX12V/ EPS12V 680W
http://www.newegg.com/product/product.asp?item=N82E16817148022
Case: (Keeping what I have) RAIDMAX Mustang ATX-889WBP Black SECC Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.asp?Item=N82E16811156164
Video Cards: Screw that, do I freakin need one if I have onboard mobo video? I mean, I'm not a gamer - I'm a video/multimedia kind of guy.
My Main concerns are any compatibility issues - will all these work together?
Also, I would like any suggestions on improving.
I'd appreciate any assitance. Thanks.
You can do better than Aspire for the power supply, I would go with a quality brand. 680w is meaningless if the power supply is using generic components. 680w is way overklll for your system anyway. Go with a quality brand such as enermax, seasonic, or fortron.
Ditto. Also, you might want to consider a beefier video card if there's a chance you might go with dual monitors or windows vista.
