C++ question!
kamper
5,513
However, if you combine the idea of my pseudo code with his code you'd be drawing both lines at one time. You'd probably have to modify mine a bit cuz it took some shortcuts.
Think about it this way:
You have a variable specifying the place to make a mark for the tl to br line. You have the same for the tr to bl line. tlbr starts at zero and goes up one each time you start a new row. trbl starts at width and goes down one each time you start a new row.
For each row you iterate over the width and each time your index matches either tlbr or trbl you print an X instead of a space. It would get a little trickier if you're dealing with something that's not square, however.
notfred
38,241
4
Originally posted by: kamper
Originally posted by: notfred
I forget the syntax for cout, but the logic is correct.
for( int ii = 0; ii < height; ii++ ){
for( int jj = 0; jj < width; jj++ ){
if (ii == jj){
cout << "Z";
else{
cout << " ";
cout << "\n";
Maybe I'm reading that wrong but won't that draw a line from top-left to bottom-right?
So reverse it. He said he was having trouble drawing a diagonal. If he wants to do it the ther direction, he olny has to change one line:
for( int jj = width; jj > 0; jj-- ){
imported_jediknight
343
Originally posted by: BingBongWongFooey[
edit: and remember to free() whatever you malloc() (or calloc() for that matter) after you're done with it; I forgot to. ;)
edit2: nevermind, I forgot again that you're using c++. don't use malloc/free
Yes, it's new and delete, or new[] and delete[] (don't mix and match!)
WarDemon666
2,224
if (ii == jj){
cout << "Z";
else{
cout << " ";
cout << "\n";
omg. never thought of changing the for :S i also have to add a + 1 to count == linecount, or else its not aligned. thanks guys!
notfred
38,241
4
Yeah, to make your Z's go the other way, count down through them instead of up :)
It's obvious you're new to this, but once you get the hang of it, this kind of thing becomes intuitive.
WarDemon666
2,224
You think theres another way to do this? now im stuck on the X. lol. But you don't have to help, ill try and figure this one on my own
Barnaby W. Füi
12,343
But it's best to just avoid explicit memory allocation/deletion altogether, by allocating things on the stack, and using STL containers. (I pretty much never use new or delete)
notfred
38,241
4
Change one different line:
if ( (ii == jj) || (width-ii == jj) ){
WarDemon666
2,224
ah crap, i got the V, but its supposed to look like this:
edit: was messed up, check out the code
any ideas? gotta move it over one and add one in the middle at the end, but thats not 'good' programming is it?
kamper
5,513
Good work! If you can do the V you can probably handle most letters that have more than one line at a time. I think that your problem will depend entirely on whether or not an even or odd width is specified. If it's even you'll get that double at the bottom and there's not much you can do except modify the width (which would go against your requirements). Put in an odd width and it should line up nicely.
WarDemon666
2,224
In the example they used 5 as the width, thats what I used, and i didnt get the same thing :(
edit: i got it. had to change count == linecount +1 to count == linecount +2 WTF.
ok this is weird. tell me what you guys think of the code, is there a better way?
kamper
5,513
I figured that a width of 5 would produce the V shown below. By saying that count = columns * 2 you've doubled your width, imo.
However, if this is what you want then I would change count = columns * 2 to count = (columns * 2) - 1. Or +1, depending on if you want round down or up.
WarDemon666
2,224
We have to do it exactly as on the sheet, and it looks like how I did it, so im guessing she had to double her width also?
Anyways, ill leave it like that, any suggestions?
I used a "switch case" to find the code for the specific letter instead of using an if statement, does this make sense? we didnt go over the switch yet but i found it out, as I already knew about the select case from vb.
im tired
Thanks ppl
kamper
5,513
A switch is fine. It's a little more dangerous, syntactically speaking, since you have no curly braces to delimit each option and you have to remember the break statement everytime but it makes more sense, semantically speaking, for constant values like characters. Wow, I'm tired too :shocked:
