C, and data structures, and.. stuff
Originally posted by: BingBongWongFooey
I think the issue is not specific to C and C++, but programming in general; "should I learn low-level stuff first, or high-level stuff first?" I honestly don't think it makes a *huge* difference, it probably is much more dependant on the individual.
IMHO, the "technical level" of a language is a completely different thing from its "level on the learning curve". C is a great language, there is no doubt about that, but I would start learning programming with some language that enforces more displines.
Such as...?
Well, I started with BASICA, went to QuickBASIC, then Visual Basic, since my options were limited (both by money and by hardware - or lack thereof). Now, I'm learning C++, which I thought was somewhat Object Oriented (though definitely not totally so), because I thought it would be a good and useful language to learn.
Certainly you won't suggest Java, will you? Because I'm sorry, but I want to learn a language that is used in the real world to solve real world problems that might face the "average person" (yes, I know Java is used for some server-side stuff, but that's not what I'm interested in). If you have suggestions that are more practical, I'd be open to hear them. 🙂
Such as...?
Python 😀
Such as...?
When I was writing down "some language that enforces more displines", I did have exactly Java in my mind. 🙂 Here again is the issue that the best language to start learning programming isn't necessarily the best one in reality, but such one does do a better jon in helping a beginner gain the necessary concepts, displines, and patterns. C isn't a good start point, because it's got a lot of pitfalls for beginners - one well-known example, can you quickly tell me what "i=1,(++i)+(i++)" evaluates to? Visual Basic isn't, either, because you don't see the "whole thing".
On a side note, Java *is* "a language that is used in the real world to solve real world problems that might face the 'average person'". As you have realized, it's being widely used on the server side, and on desktop it's also starting to gain popularity because of its portability and much more improved performance.
Originally posted by: Mucman
Yes O(1) is similar to O(c). By saying O(1) though you are saying that you gaurantee every hash table lookup will involve 1 comparison and you are
done. This is usually not practical because of memory limitations, and doesn't address possible collisions.
Just double checked my analysis book, 🙂 Seems you can prove by definition that O(1) equals O(c), where c is a constant. I think there isn't a theoretical term to differentiate a strict no-miss hash from a may-have-a-couple-retries one. There probably isn't any practical reason for us to differentiate them, either, since the performance difference is trivial.
ok, I don't think I explained myself properly though. Yes O(1) is O(c). O(1) implies absolute unique hashing and no collisions. If you made a table with
one bucket, and you insert n elements into that table, you will have O(n) selection. So I believe what I am trying to spew here is what is the O(1) of tables
in python refering to? Best case, worst case, or average case? O(1) defintely seems to be the best case, while I would believe that the average case is
O(1 + c) where c = (percentage of overflows x average overflow length). I would bring out my algorithms book, but it's too darn heavy to lift 😛
I could see that... Perhaps I shall try Java after I finish learning C++. 🙂
BTW, I picked up "Core JAVA 1.1" (Volumes I and II) for US$0.50 at a used book sale at a local library. I'm sure the volumes are slightly dated, but I'd like to know if I could learn anything (even just the basics) with them. Or, will I need to spend more $$$ on a new, up-to-date book when I'm ready to begin that project?
I'm learning C++ - not C - but I'm not sure if that makes much difference in relation to what you are saying here.
Oh, and I'm still a n00b to C++, so I haven't studied the , yet, but wouldn't "(++i)+(i++)", given i = 1, produce 4, with i being 3 after the expression evaluates? How the comma relates to that, and what i finally ends up being, I'm not sure. Heck, I'm not even sure of what I just said. 😱
I still wouldn't write the next open-source Photoshop killer in it, but I guess it would be fine for less demanding situations. In my experience, application startup time still seems to be a very big issue, but I suppose if I was just wanting to write a small to medium sized application that needed to be very cross-platform compatible and didn't need any low-level access to anything, Java would be fine. Hey, I guess you've got me convinced. I'm still going to finish what I've started, but barring an unforseen change of plans, Java shall come next after C++. 🙂
I would look at C, because it's very closely related to C++. You'll understand C++ better if you read about C first.
Trying Java after 5+ years of C++ was weird for me. I had a lot of trouble adjusting to Java, and was annoyed with the different programming approach and limited capabilities.
I doubt Java will ever become a good application language. It is much weaker than C++ as an application language - it's slow, doesn't support pointers, operator overloading, or templates, and although it is portable, debugging it on different operating systems can be a pain the ass.
The US military uses java for some applications (I worked an internship for a company that contracts with them and one of the projects of the other interns was to do some work on a java program they had). I, personally, don't like the language, but it does get used.
Pretty much every language is used in the 'real world', even languages that everybody thinks are entirely academic such as Lisp.
I know I'm getting a bit pedantic here, 🙂 but anyway, my point is that it is not mathematically correct to use O(1) and O(c) to differentiate the performance of any algorithms/data structures, because O(1) does not imply anything more or less than O(c) whatsoever, and vice versa. I absolutely agree with your opinion on the collision/overflow characteristics of hash tables, but I'm pretty sure you cannot find in any algorithm book they are described using O(1) and O(c).
The best scenario of a hash table is O(1) (which again does not necessarily imply exactly 1 hashing), and the worst O(n). As matter of fact, there isn't a single one hash table in real life can guarantee exact 1 hashing, but the statement above still holds true, exactly because O(1) includes those scenarios where a constant number of hashings are allowed.
Java 1.1 is *very* outdated, I would say. Consider it Sun's "pilot" to the real Java, i.e., Java 2. 🙂
Actually, the evaluation of that expression is compiler dependent, because C(nor C++ for this case) doesn't have a clear definition on the expression order - one compiler might decide to follow the textual order, another one might optimize to do ++i and i++ together, etc.
The perception of "slow" is relative; many times shaving CPU cycles has a far less ROI than saving programmer time. Also, generic (templates) will be available in Java 1.5 "Tiger".
ok, I understand what you are saying now 🙂
