trmiv, dont forget that that could easily be 1 32mb and a1 64mb module.
How?
the 32mb is double sided (chips on both sides), hence 16mb PER BANK, then the 64mb module is single sided, hence that bank as 64mb.
2 DIMM slots are being used right now.
If the mobo has 3 DIMM slots, then you can just pop in another 32mb'er, but there's also a chance that you may only have 2 DIMM slots to begin with, which means you either need to:
#1. take out the 32mb you have and exchange it for a 64mb (total = 64 + 64 = 128)
#2. Take out both 32mb and 64mb sticks, and put a 128mb stick straight in there
The 128mb stick would be much better because
#1. It's likely to be higher quality than what you presently have
#2. You have upgrade space for later 🙂
How?
