Queasy
Moderator<br>Console Gaming
- Aug 24, 2001
- 31,796
- 2
- 0
Originally posted by: sourceninja
I shelled out the cash for the wireless adaptor for the 360. It works without a hitch at my house. The ONLY complaints I have are this.
1) It does not support WPA2, but shows it as an option you can't select. (the manual says WPA2 support is planned, but not supported).
2) It did not work at all until I connected without an security (had to turn off wpa) and did a system update.
After that it is working fine with WPA-PSK. I have had no issues playing games online or downloading content. There are a few wireless networks in my area too.
Yeah, I had the exact same quirk. You have to turn off the security on your router, connect, then turn on the security on the router and adapter.
I was pulling my hair out with that part.
