tortillasoup
- Jan 12, 2011
- 1,977
- 4
- 81
A couple of months ago, dropped $1900 on an LG french door, delivery and removal. Hurt my heart.
Regardless of brand, you should put an appliance surge protector on it and you should pull it out every few months and clean the coils. Supposedly the compressor runs 24/7 on our model and if the compressor burns up because of build up....voided warranty.
Ice makers will leak. Sooner or later, they or the supply line will. I didn't hook ours up. Trays work fine....since I don't use ice.:sneaky:
Depends on the room temperature but for the most part, NO a compressor should not run 24/7. Check to make sure the EVAP and Condenser fans are spinning at a proper speed. It would have to be about 75F+ ambient temperatures for a compressor to reasonably running at a 80% duty cycle.
Sorry, but that makes no sense at all, Sears builds nothing, they just put their sticker/badges on other manufacturer's products. Some of the stuff is built just a little different, but most isn't. The refrigerator I bought is a Kenmore, made by LG.
If you read what Consumer Reports says, they do not recommend fixing refrigerators beyond very simple stuff, a 10 year old refrigerator is much less efficient than a new model. The one I bought is huge and uses 30% of the electricity of the one it replaced.
10 year old refrigerators aren't significantly less efficient than modern refrigerators especially if you already had an energy star model. Anything made after about 2004 or so that's an energy star appliance isn't going to see a significant improvement in efficiency. Literally saw only about a 100kwh a year difference according to the tag of a 2015 model vs a 2005 model refrigerator of similar size. Now if your refrigerator was made in the year 2000, that's a different story as the standards were significantly lower then.
