mvbighead
Well, I had to do some wrenching this weekend, and found that my current jack, though it works, is just too much of a pain in the arse to get anything done. I literally have to jack up/down in stages, or so it seems.
Any hoo, this is what I have:
http://www.tractorsupply.com/powerbu...-stand-1160455
I bought it because it had the lift range I needed, and it was cheap. Perhaps if I used the built in jack stand feature, and locked it in place, I'd have been fine. I just don't necessarily trust it, and prefer to use jack stands.
So, now that I have a big enough garage, I figure it'd be good to invest in a full sized jack, and not some trunk style jack.
If you were to spend $100 (plus or minus 20 or so), what would you pick up?
I am considering the following:
http://www.harborfreight.com/25-ton-heavy-duty-floor-jack-with-rapid-pump-68049.html
20" max lift, 72lbs, 2.5 tons
http://www.harborfreight.com/3-ton-heavy-duty-floor-jack-with-rapid-pump-68048.html
18.25" max lift, ~70lbs, 3 tons
http://www.harborfreight.com/15-ton-lightweight-aluminum-racing-jack-with-rapid-pump-68054.html
17.75" lift, ~38lbs, 1.5 tons
I am leaning either towards the 20" lift one, just as it has the max lift of the three, or perhaps the "racing" aluminum jack. I am not terribly worried about the weight of the jack, but thinking about a 70lb jack is a pretty big jump from a 40lber.
In any case, I think all three should be leaps and bounds better than what I have now. Other retailers to consider? Other factors to consider?
Edit: Current vehicles include a 2000 Jeep Grand Cherokee and a 2007 Chevy Impala. Am currently looking at a "work" truck that will likely be a (1996-2002) Chevy Silverado 1500 (perhaps 2500) 4x4 as well. I would like the jack to work for all three.
