Furor, that's a good price. Provantage's return policy (or, basically, no returns policy) always scared me away, but for $100 less that might be worth it.
SMC's web site doesn't work for me either. When it works, it is a pretty terrible web site... hard to get around on, and you just get innundated by products with similar descriptions. You can get info on this product using Google's cache right now.
This is not a "managed" switch, it's a "web managed" or "smart" switch. Basically, that's a class of switches that are between "managed" and "unmanaged." Make no mistake, a full managed switch with a CLI, serial port, SSH server, SNMP support, and spanning-tree support is what you are better off getting. But if your budget makes that impossible, crippled management beats no management.
This switch has a web UI, no CLI, no serial port, and I believe some SNMP support (in recent firmware). It has nothing resembling a CLI and no spanning tree support. That's enough to let you do things like get diagnostic counter information about ports, do some manual port speed/duplex configuration, and set up VLANs. It's enough to save your hide if there's a bad NIC or a bad cable in your network. But it's not a real managed switch and the little things that are missing (and the big things that are missing) are a real cripple. So it's better than an unmanaged, but not as good as a managed.
All switches I've seen come with a default factory configuration of acting like a big and basically dumb switch out of the box, so yes, with no configuration it will basically work like an unmanaged switch.
SMC makes real managed 24 10/100 + 2 10/100/1000 switches for about $300 (that's Newegg's price) that are good quality, and I believe the 48 10/100 + 2 10/100/1000 is about $500. I'd also suggest you look at those. If you don't absolutely need gigabit to the ports, you would be better off with a full featured switch at the same price point. In particular, spanning-tree is a big win when going out to end user ports.
