Buying 2407wfp, Best way to get sound out of my HD DVR box?
Jules
I currently have no speakers i use headphones and im returning my old tv set. How would i go about getting sound out of my HD DVR box? What kinda speakers under 100$ would do that?
alaricljs
1,221
Well you haven't told us what DVR you have, so we can't go look up what kinds of audio connections it has which you also didn't tell us.
So the answer is: Whatever kinda speakers will work with whatever kinda DVR you have.
Jules
I got a DCT3416 I
alaricljs
1,221
Well, there's nothing on the net as far as audio outputs... and the manual isn't available online. So you're going to have to look at the back of the box or dig out your manual.
Steve
15,945
11
I have a set of Logitech Z-5500s that can accept the optical, coax, or analog connections from my DCT6200-2005 tuner.
Jules
Steve
15,945
11
I like my Z-5500s and all, but the thing about them is that there's no upgrade path. Buying individual components lets you start with a receiver and a pair of speakers, then later add a sub, then more speakers, then upgrade your speakers, etc. over the years.
Jules
i really only want 2.1's though. i really have no use for 5.1's. My Box also has Component, thats what i would be using for my 2407WFP when i get it today. I have a Headphone jack to L and R audio plug so i can always connect it though there.
Steve
15,945
11
Then no need for the 5500's, which are a 5.1 set. Get the receiver and look for a pair of speaks and a sub, or if you want to go the PC speaker route, I hear good things about Klipsch 2.1 sets.
Jules
My DVR has Component. I was thinking of hooking up the component of the 2407wfp and using THIS and connecting The Klipsch 2.1 sets. Will that work? i can always swap it out when i need to use them for my comp
Jules
Nevermind, i think im going to use some X-230 Logitechs i got laying around to watch tv with.
