Hey guys.. Here's the deal, I'm buying a new 19" monitor and it needs to be superb quality.. Since I do alot of design work as well as gaming.. i have a list of a bunch and maybe you guys can help me out as to which one is the best..
I *NEED* 1600x1200@85hz
anyways heres the list..
mitsubishi Diamond Pro 930SB
0.24mm Aperture Grille
max res 1920x1440 @ 73hz
samsung SyncMaster 950NF
samsung SyncMaster 957MB
0.20mm
max res 1920x1440 @ 64hz
viewsonic p95f+
0.25mm Aperture Grille
0.27mm at corners
max res 2048x1536 @ 68Hz
sony CPD-G410R
max res 1800x1440 @ ??hz
Sony CPD-G420S
anyone have any info on the differences between the G420S and the G410R?? seems their specs are the exact same and so is the description on sony's site..
If you guys could help me out as to which one is the best out of the bunch for graphics/gaming and can do 1600x1200@85hz it would be much appreciated..
thanks
0.20mm
viewsonic p95f+
0.27mm at corners
sony CPD-G410R
Sony CPD-G420S
thanks
