3DVagabond
- Aug 10, 2009
- 11,951
- 204
- 106
I'd say that's a pretty sizable difference (~16%). It's especially bad if you consider that the 670 isn't exactly a high bandwidth monster.
That review used a stock 7950. Check back for the links I posted. GTX670 is 36% faster than a 660Ti in Batman AC with MSAA once both are overclocked. that's huge. In Skyrim with mods, a GTX660Ti is 41% slower than a 7950 925mhz with 8xMSAA. So yes, it falls apart with MSAA. Unless a person can find a GTX660Ti for $250 or below, it's throwing $ away. HD7950 @ $275-320, HD7870 for $200-240 or GTX670 for a deal @ $330-340 are all better. GTX660Ti is a very poor card for $300. I can't say 1 nice thing about GTX660Ti other than it comes with BL2. When you add MSAA and higher resolutions, 660Ti can barely keep up with a GTX580 and loses to the 7870 at times. For a card that costs $300 in September 2012, that's unacceptable.
Check out HardOCP's review of GTX660Ti vs. 670 vs. 7950 OC. The only outlier there is the 660Ti, it fails to compete despite being a 7950 competitor by price at the moment.
To gauge if AA falls like a deck of cards one may test apples-to-apples with a GTX 670, considering the GTX 670 has a 256-bit bus and the GTX 660 ti has a 192 bit bus, by utilizing extreme settings and resolutions.
Some-how it becomes what GPU is important to recommend and about the HD 7950.
The investigation showcased an apples to apples clocking of a GTX 660ti vs GTX 670 and there was no falling apart -- offering the impression one can't use AA. It used a HD 7950 with boost. The site even used x32 AA, transparency and forced ambient Occlusion for crying-out-loud.
We found that the higher the MSAA setting, the greater the performance delta. For example, it was 25% faster at 32X CSAA, then went down to 21% faster at 8X MSAA, then went down to 15% faster at 4X MSAA. So it seems as the MSAA demand increased, the GTX 670 had a stronger lead.
You need to re-read.
I'm still rocking with my 2 GTX 460 1GB heavily overclocked. There's no reason for anyone with these cards to upgrade until the GTX 1160 Ti comes out in 2025.
Actually it makes my point -- even with x32 AA it doesn't fall like a deck of cards, sure, there is more of a percentage but considering the GTX 670 is 33 percent more MSRP-- falling like a deck of cards is extremism.
I have buyer's remorse with my 7950 wind force. My remorse is I should have gotten this thing sooner, it mines incredibly well so if I had bought this a 6 months earlier I could have probably paid it off and been able to afford another one by this point. Then again the price on these 6 months ago was probably much higher so maybe not.
FTFYBitcoin mining might work, and it's touted and promoted endlessly by AMD fanboys. You can use your videocard to make you $ when you are not gaming because it's not a feature in AMD's slide deck or on any of the AIB's partner websites. PhysX, TXAA, AO, 3D Vision, those are all real advantages -- free GPUs and cooking the thermal pads on your VRM's are made up! :thumbsup:
