Burnt my hand with a can of compressed air... (UPDATE)
CarlKillerMiller
3,099
Originally posted by: Skoorb
Hold a match to it. The heat damage from that will negate the cold damage from the compressed air and your skin will heal up fast.
amazing Idea. I cured a gunshot wound the same way.
zixxer
7,326
Shot yourself from the other side to counteract it? Interesting idea..
Howard
47,986
11
Originally posted by: MagicianBdotCom
My friend, got sprayed by his friend VERY bad once. His whole forearm was burned and all the skin peeled off and such. It was disgusting. He was a weird kid and so he'd always show it off and stuff just to freak people out. It took like the whole school year to heal and it still looks gross where it healed 'cause it's all scarred up. Do those cans have warning things on them?? Why does it happen when you flip the can?
Aerosol cans use a highly compressed gas as propellant. When positioned right-side-up, the liquid is at the bottom and the gas is at the top. A tube from the top to the bottom of the can is sealed by a valve, which is opened when you push on the button at the top. The gas exerts pressure on the liquid, and the liquid goes up the tube to be aerosolized when it exits the nozzle.
When you flip it, the gas is at the top, and it goes out the tube when you push the button. Because it's at room temperature and very high pressure, when it comes out, it'll be at normal pressure and very low temperature (gas law).
EyeMWing
Banned
Jun 13, 2003
15,670
Spray your coworker in the gonads next time you get a chance. And fsck the compressed air - use a nylon paintbrush. Won't get rid of all the dust, but it'll make it decent and you don't risk freezing the components to death.If it did that to your HAND, imagine how all those tight little motherboard traces felt getting hit with cold air and contracting.
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
So any idea what these tiny little itchy bumps are now surrounding the area that got frozen?
Ketteringo
Banned
Feb 2, 2002
4,302
Drink alcohol, lots and lots of alcohol :) Either that or cut off one of your toes, and the pain from that will be so bad you wont even care about a little burn.
Sid59
11,879
wth? man im so sorry
use butter ... hahahahahah
nah seriously .. ice and some beer.
Howard
47,986
11
Bugs, most likely. :D
