StageLeft
- Sep 29, 2000
- 70,150
- 5
- 0
Don't worry about itOriginally posted by: THESANTINI
what sites do you reccomend for target heart rate? what % of your maximum is the target for cardio?
Originally posted by: Skoorb
What a pathetic cop out.Originally posted by: shud
A little OT, I have extremely crappy metabolism. Excercise just doesn't do it. How safe is ephedrine or xenedrine or whatever that stuff is? I've known people who've used it with success but I'm always wary of that stuff.
OP: cut those cheat days down to one/week, max.
Originally posted by: IBuyUFO
Go on the south beach diet. I lost 10 lbs [6 of which were water, two of fat, and two of muscle] in 2 weeks with no exercise.
If your metabolism is really that bad go to the doctor and get your thyroid levels checked. If your thyroid isn't working properly it can affect so much more than your metabolism.Originally posted by: shud
Oh, I've never heard that before. I have absolutely perfect blood pressure and all cholesterol is perfectly fine. I worked 12-14 hour days manual aerobic work for more than 30 days in a row with a 30 minute lunch break and no breakfast last summer. My diet regularly is sub 2,000 calories a day. At a check up for some ADD meds at the end of the summer my doctor was amazed that I hadn't lost weight, and recommended I see a dietetics (sp? or maybe not even the right word) expert because something was probably genetically borked. Obviously I never did, I figured I could handle it myself but it's not going so well.
Just because you don't have a problem with it doesn't mean someone else doesn't.
You're not analysing the situation properly. It's a physical impossibility that exercise doesn't work for you, unless you're going to tell me that you've figured out a way to move your body without exerting calories. That would be a scientific breakthrough. So your metabolism sucks, so what? Eat less. You got fat because you ate too much PERIOD. That's it. You sure as hell can lose fat by eating less than your daily maintenance requirements. Whether they are 3000/day or 150/day, if you eat less you'll lose weight. You can eat less, or you can maximize your requirements with exercise. In any case, if you consume less calories than your body requires to maintain itself, you'll lose weight.Oh, I've never heard that before. I have absolutely perfect blood pressure and all cholesterol is perfectly fine. I worked 12-14 hour days manual aerobic work for more than 30 days in a row with a 30 minute lunch break and no breakfast last summer. My diet regularly is sub 2,000 calories a day.
Most thyroid problems are "just genetic" too. The point is that there is often something a doctor can do/recommend to help you get over some of the limitations of your genetics. You said you've tried exercise and proper diet and it didn't really work. That is all you can be reasonably expected to do yourself. The next step is to get some input from a professional. They are way more qualified to "help you help yourself" than most anyone on these boards.Originally posted by: shud
I've known people with Thyroid problems, this is not like that. It's just genetics, and if that last summer of work didn't alter my metabolism, I don't know what will.
dr150I think there's nnothing wrong with some calories late at night. I always find it savvy advice to have, just prior to bed, a high protein low-carb meal. It can be as small as a scoop of protein, but you don't want to be going 12 hours without food. That's a sure-fire way to muscle catabolism.
Also, whether fat burning starts after 20 minutes or not, if you're burning calories in that 20 minutes--which you are--those are calories that won't go towards maintaing your body, so later on your body will end up using fat to burn off fat. A great many people these days are doing cardio that doesn't exceed 20 minutes, and getting great benefits from it. I'm currently as thin as I've been in a decade and my fat is still going off at a ridiculous pace, but my running is only about 25 min (and more than two weeks ago it was maxed at 20).You're not analysing the situation properly. It's a physical impossibility that exercise doesn't work for you, unless you're going to tell me that you've figured out a way to move your body without exerting calories. That would be a scientific breakthrough. So your metabolism sucks, so what? Eat less. You got fat because you ate too much PERIOD. That's it. You sure as hell can lose fat by eating less than your daily maintenance requirements. Whether they are 3000/day or 150/day, if you eat less you'll lose weight. You can eat less, or you can maximize your requirements with exercise. In any case, if you consume less calories than your body requires to maintain itself, you'll lose weight.Oh, I've never heard that before. I have absolutely perfect blood pressure and all cholesterol is perfectly fine. I worked 12-14 hour days manual aerobic work for more than 30 days in a row with a 30 minute lunch break and no breakfast last summer. My diet regularly is sub 2,000 calories a day.
If you were doing 12-14 hours of intense physical activity on 2000 calories day and lost no weight you're either lying (maybe not deliberately; most people haven't the first clue about how many calories they really take in), or you are 3.5 feet tall and weight about 50 lbs. Exercise requires energy. When you move things, that requires energy. Don't pretend that one guy who just went for a run and burned 1000 calories is doing it inefficiently and somehow, magically, your body is able to do the same 8 miles at a 100 calorie expenditure. It's very simple. Also, things like skipping breakfast are just a bad idea anywayEat throughout the day. I've never met a person who ate 1-2 meals a day and wasn't at the same time overweight. It leads itself to overeating and low lean mass.
most of my questions and concerns have been covered, quickly, on work time, fantastic.
last question is shooting for the timing, which I don't understand what goes on after 20+ mins of jogging that doesn't happen during the first 20?
Your body temp gets higher which burns more calories. thats why too much swimming doesnt burn a lot of fat b/c the water keeps your body cooler and doesnt allow it to reach as high of a temp
