- Oct 12, 2004
- 5,139
- 1
- 0
Hello,
I am having a problem with my burner. Its a Yamaha external SCSI 4x4x16 burner. It wont burn cd's at all. I had it connected to the SCSI chain I have. Here is whats going on.
I put a cd in the burner. I open Toast Titanium, and drag some data onto the window. Then, I click record. So when it is beginning the burning process, I get this error:
"The drive reported an error:
Sense Key=HARDWARE ERROR
Sense Code=0x09, 0x02
FOCUS SERVO FAILURE."
I thought it may have something to do with the chain. So I connect the external burner to my computer by itself. I try to burn the same cd, and I get the same error, except some parts of the error is different. Sometimes it will say:
Sense Code=0x09
TRACKING SERVO FAILURE."
Then, a friend of mine told me to try slower media, which I dont have. Also, when I purchased the burner from my friend, she had an empty Sony CD-R 48x cd, so she must have been burning using these cd's. So I decided to try the Sony cd, and see if it works. And it didn't. Same error. Not only that, when the cd is failed to be written, the drive dies, until I turn the power button off, and turn it back on. When I say it dies, the eject button doesnt work. I have to manually push the tray closed. Then when I want to open the tray by pressing the eject button, it doesnt open. So I turn the drive off, and then turn it back on, which brings it back to life. But of course, I still cant burn cd's.
Any idea whats going on? Could the drive be bad?
Thanks for looking, and sorry for the long post.
Sense Code=0x09
