- May 6, 2004
- 353
- 0
- 0
Hey ya'll.
I just built a computer with parts I had lying around and to the best of my knowledge they all worked before hand. Anyway without running post this is what kind of info I can give you.
AMD Athlon? 1.6Ghz
Mobo...unknown (can't find a tag or anything on it)
ATI Sapphire PCI 64MB Card
300W PSU
512MB DDR226
CD-RW
CD
WD HDD 13.5
Floppy
NIC
Anyway without anything plugged in (including the Vid and the NIC) it gives me a long beep then silence then a long beep. I shut it off. Turn it back on and don't get anything. REPEAT!
This happens whether or not anything is plugged into the mobo. I've looked up beep messages and double check all connections but nothing seems to help. Any advice?
AMD Athlon? 1.6Ghz
300W PSU
512MB DDR226
CD-RW
CD
WD HDD 13.5
Floppy
NIC
