I'm the process of building my new computer and I would like someone to check if everything is compatible.
AMD ATHLON 64 3200+ PROCESSOR S939 VENICE 2.0GHZ 512K L2 CACHE 90NM RETAIL BOX
SEAGATE BARRACUDA 7200.7 120GB HARD DRIVE 7200RPM SATA W/NCQ 8MB 8.5MS 3.5IN 5YEARS MFR WARRANTY
ASUS A8N-E MOTHERBOARD ATX S939 NFORCE4 ULTRA DDR PCI-E16 PCI-E4 2PCI-E1 3PCI SATA RAID GBLAN SOUND
CORSAIR VALUE SELECT PC3200 1GB 2X512MB DDR400 184PIN DIMM DUAL CHANNEL MEMORY KIT
CONNECT3D RADEON X800 XL PCI-E 256MB DDR VGA DVI TV-OUT VIDEO CARD
And a SONATA II case (already on the way).
Also, I'd appreciate if someone could answer these questions.
Is the 3000+ worth getting instead of 3200+? I hear they have almost identical performances? I'm not planning on doing any overclocking though.
I will be using my computer mostly for gaming, is the SATA harddrive worth getting? Is the installation the same as IDE?
How does the X800 XL compate to 6800GT? What's the better choice atm?
Thanks in advance.
Thanks in advance.
