CrimsonCutie
Hey every1
I am building a new system, its been about a year and half since i did my last box. I am posting a list of the hardware for review. I would appreicate: 1) anyones known issues with compatibility of the compoents i have selected, 2) thoughs of improvements/changes, 3) general thoughts of system. You can also rate the system on the poll.
You can click this direct link to a NEWEGG.com list of parts (and from that get detailed specs)
NewEgg List of Parts
Main RunDown
-MSI K8N Neo4 Platinum Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard
-BFG Tech BFGW68256GTOCXV Geforce 6800GT 256MB GDDR3 PCI Express x16 Video Card
-Antec TruePower 2.0 TP2-550 EPS12V ATX12V 550W Power Supply
-AMD Athlon 64 X2 4200+ Manchester 2000MHz FSB Socket 939 Dual Core Processor Model ADA4200BVBOX
Which memory do you recommend??:
-CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model Twinx2048-3200c2pt
-OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Platinum System Memory Model OCZ4002048ELDCPE-K
-Seagate Barracuda 7200.8 ST3300831AS-RK 300GB 7200 RPM Serial ATA150 Hard Drive
-Pioneer Black IDE DVD Burner Model DVR-109 BK
-NEC Black IDE DVD Burner Model ND-3540A
Which SoundCard do you recommend?
-CREATIVE Sound Blaster Audigy2 ZS Platinum
-CREATIVE Sound Blaster Audigy 4 Pro 8
-ZALMAN CNPS7700-CU 120mm 2 Ball Cooling Fan
Thanks in advance
Jaysin
Main RunDown
Thanks in advance
Jaysin
