Are all G Skill Ripjaws V series working fine with zen?
Most works really well with manual setup / tweaking after the AGESA 1.0.0.6 update.
But, Ryzen and RAM "working" is kinda a loaded question, some works better than others.
You should be fine, read bellow:Damn! I ordered the wrong kit.
RAM: G.Skill Ripjaws V Series 16GB (2 x 8GB) 288-Pin SDRAM DDR4 3000 (PC4 24000) Intel Z170 Memory Kit F4-3000C15D-16GVKB
Source here.F4-3000C15D-16GVKB - G.Skill Ripjaws V Series 16GB (2x8GB) Single Rank containing Hynix M-Die - JEDEC
I've often claimed to have had very good luck with my choice of ram with my Ryzen build, regardless of the fact that I didn't choose from QVL or do any sort of research prior to purchasing. When I assembled my build, I updated my ASRock AB350 Pro4 bios to the newest version at the time (I think 2.60) before I even installed Windows, and it loaded XMP 2933 without fault. The only problem being the odd-numbered CAS Latency issue with Ryzen boards; 15 defaulted to 16. That being said, I've even had fairly good luck overclocking the kit to 3200 with timings: 16-16-16-37-55-CR1 at 1.40v, but I haven't went into the secondary or tertiary timings yet to see how far I can push it.
I wanted to show my current progress at 2933. I've tightened the timings from the XMP default 16-16-16-35-51-CR1 at 1.35v to 14-14-15-35-51-CR1 at 1.35v with secondary or tertiary timings tightened as much as I can get them. I verify stability with Memtest86 - 10 passes of test #6 all cores parallel (takes about 20 minutes). I'll post screenshots of Ryzen Timing Checker along with Aida64's Cache and Memory Benchmark. I'm pretty sure my math is correct, feel free to double-check.
All if my Ryzens and threadripper run on Flarex or (mostly) Trident Z or ripjaws, its virtually all the same ram.Are all G Skill Ripjaws V series working fine with zen?
Just as an alternative line of thought, we're so close to 5xx series chipset boards (PCIe 4.0, will be handy for faster SSD down the line, better USB etc), consider wait at least through the AMD keynote coming up shortly?
You can score a passable AM3 board to wait things out with your current stuff, then sell it as a complete combo later on.
Or, sell the 8350/ram/etc and score a cheap used workstation to get by with until the upcoming Zen2/3000 series hit the streets.
You could conceivably get a 5xx mobo, and get a cut rate deal on a 2700x if you so wanted, or go for 3700 or whatever.
Normally I'm not the biggest 'wait and see' type of guy, but we're so close to 500/Zen2 that it would be the least comfortable time for me to buy a 4xx/Zen/Zen+ or Intel anything until we see what the deal is with the new stuff. It's primed to be one of the bigger leaps in a long time in regards to features as well.
I wont be overclocking or setting up RAID so why would I not get the B450 below over the X470?
$109
ASRock B450 Steel Legend AM4 AMD Promontory B450 SATA 6Gb/s USB 3.1 HDMI ATX AMD Motherboard
$129 (salel ends in 10hrs regular price i think was $160)
ASRock Fatal1ty X470 Gaming K4 AM4 AMD Promontory X470 SATA 6Gb/s USB 3.1 HDMI ATX AMD Motherboard
I've been eyeing that one. It looks like a REALLY sweet board.$129 (salel ends in 10hrs regular price i think was $160)
Board:
Gigabyte B450 Aorus Pro Wi-Fi.
B450 chipset, Intel LAN, Realtek 1220 audio, Wifi + bluetooth, aRGB, dual m.2 slots, very good UEFI, sensible stock fan curves, aggressive precision boost 2.
No board comes close in features and performance at its price point. Keep the UEFI at F5 (AGESA PinnaclePi 1.0.0.6) as its memory compatibility is the best.
Looks good, but what about the video card ??Thanks for the help, here's the outcome, hopefully completed by the end of the week as long as everything comes in.
AMD Ryzen 5 2600X ($188 Shipped)
GIGABYTE B450 AORUS PRO WIFI ($125 Shipped)
G.Skill Ripjaws V Series 16GB ($99 Shipped)
Samsung 860 PRO 512GB V-NAND ($157 Shipped)
CORSAIR HYDRO Series H100i PRO ($115 Shipped)
CORSAIR RMX RM650x, 80+ Gold Certified ($94 Shipped)
Going to keep my 570 until AMD drops their new ones later this year. I almost pulled the trigger on a Vega 56 since the Gigabyte cards were down to 299 new but I decided to wait.
I would go with the seasonic unless you already bought.Going to give a non expert tip. Newegg has a Seasonic gold 750 watt for a little more before the rebate but a little less after the rebate
$95 up front, $80 after rebate
https://m.newegg.com/product/N82E16817151201?m_ver=1
If cost isn't a issue why not buy the kits everyone recommended? Saw it was ripjaw v and thought it was the same? Also seems like x470 ultimate tachi is best? Paid 220 for mine but I bet they 180 nowThanks for all the input, here's what I have so far and cost is not really an issue.
Chip: 2600x $179 shipped
Still looking for a motherboard.
They are $250 right now on newegg. If you got it at microcenter, that does not count since most of the world does not have a microcenter near them.If cost isn't a issue why not buy the kits everyone recommended? Saw it was ripjaw v and thought it was the same? Also seems like x470 ultimate tachi is best? Paid 220 for mine but I bet they 180 now
