Don't get me wrong, I've done a lot of dumb things when I was younger (I still do them now, just not as much). But then, I realized that none of the things I did to the car was meaningful, or beneficial, so I stopped.
As most people pointed out already, most the intake area is covered up by the bumper, so that negate the "ram air effect". Secondly, I think unless you're going awfully fast, you're not going to generate more than 14.7PSI, which is the pressure going in the intake when you're standing still. Realizing that, short of FORCED INDUCTION, no gimmick is going to work.
These guys, http://www.cunningham-motorsports.com/, my friends for a while before I moved up north, can tell you all about the "Corvette intake"... lol.The ram air effect is only a few percent at best, but a better intake will increase his HP. The new airbox he is setting up is exactly how the Corvette intake is designed and will provide gains to the affect of 5-10 rwhp depending on supporting mods. Maybe a little bit more or less depending on the tune.
I view cold air intake the same as exhaust swap. Put a different one on there if you like particular sound. Just don't expect any noticeable hp gains.
Yes, they do have those intakes bolted on, but behind those intakes are usually some GIANT FREAKING SUPERCHARGERS, or TT.
That's because they SELL accessories. I'll take what I know + the shop that only does performance modification over a retailer any day.Seriously? Changes in a factory restrictive exhaust do make power (more for full systems, a lot less for catbacks). Would you like me to show you the difference in logged MAF flow from a PCM?
Stock parts are designed to meet the initial performance goals, not to create maximum performance.
http://www.lgmotorsports.com/catalog/index.php and those guys will tell you different. The stock box is restrictive but the intake design itself is not. In fact, there's a few mods that's as simple as cutting a few holes in the intake box which give a few HP on the dyno.
WTF does what I say have anything to do with anything I claimed? And, what have I claimed that needs proving? Or, are you just pissed that I crapped on your "theories"? You're pissing up the wrong tree buddy.how about posting up some of your badassery? Walk your talk here. It's getting lame to see you in every thread calling shens.
Ram air works? Yeah, on a SR-71, sure.
How about you post your links on any NA cars that gains 10HP on an air intake change. I'll wait... Since it's "proven", shouldn't take you that long, right?
I've been rolling around with the import scene since I was in my teens, and most of the crap that people sell and buy, are just that, craps. If you want to believe otherwise, your prerogatives.
http://g35driver.com/forums/tuner-dyno/203301-stillen-intake-dyno-test.html
7rwhp 10rwlb.ft
http://www.vetteweb.com/tech/vemp_0612_c6_corvette_intake/dyno_test_results.html
2rwhp 12rwlb.ft
http://forums.corral.net/forums/s-1...11-gt-jlt-cai-dyno-results-vs-k-n-filter.html
15.82rwhp 8.8rwlb.ft
Oh look, it works on motorcycles too.
You will make more power from a new intake, period. While they do not produce huge gains, they're invaluable when combined with the other major bolt-ons and a proper tune to create a complete package which outflows the stock parts. Just because JDM motors built for gas mileage in little toasters don't receive huge gains from an intake, doesn't mean other cars don't, so you go play with your little toys and let the big boys talk mkay?
I am sure you are correct, but how does this work?
If any 'ram air' effect is negligable, then where does a performance improvement come from? I presume the same filter and filter-diameter set-up stays in place, which I would have thought that would have been the bottleneck?
Perhaps my 'ram air intake' snorkel is giving me some crazy performance boost after all 😉
http://www.safarisnorkel.com/snorkel/ss185hf/ss185hf.htm
At least I know that I don't have to worry about water getting in, even in the most torrential tropical downpour 😉
dug777 that's mostly for trucks that go into mud.
Also much of the 'ram air' affect is not really the rammed air, but the cooler air charge coming in.
People seem to get fixated on there is no real pressure difference and forget the temperature one.
The motorcycle article is highly interesting, they actually check the pressure differential between the standard air intake and the ram air and found a pretty big difference, especially at speed (obviously).
