CompFreak07
$110.00 CASE (NEWEGG)
ANTEC P182 GUN METAL BLACK 0.8MM COLD ROLLED STEEL ATX MID TOWER
$90.00 MOTHERBOARD (NEWEGG)
GIGABYTE GA-P35-DS3L LGA 755 INTEL 935 ATX ALL SOLID CAPACITOR
$280.00 PROCESSOR (XPCGEAR)
INTEL CORE 2 QUAD Q6600 G0 KENTSFIELD QUAD-CORE, 2.4GHZ 1066MHZ FSB, 8MB L2 CACHE, EM64T, VIRTUALIZATION, LGA775 SOCKET 775/T CPU: BX80562Q6600
$125.00 POWER SUPPLY UNIT (NEWEGG)
CORSAIR CMPSU-520HX ATX12V V2.2 AND EPS12V 2.91 520W
$5.00 24PIN EXTENSION CABLE (NEWEGG)
ATHERNA POWER 12" EPS (24PIN) CONNECTOR EXTENSION CABLE. MODEL CABLE-AD09
$190 MEMORY x2 (NEWEGG)
G.SKILL 4GB (2 X 2GB) 240-PIN DDR2 SDRAM 800 (PC2 6400) DUAL CHANNEL MODEL F2-6400CL5D-4GBPQ
$220.00 VIDEO CARD (NEWEGG)
MSI NX8800GT 512MB OC GEFORCE 8800GT 512MB 256-BIT GDDR3 PCI EXPRESS 2.0 X16 HDCP READY SLI SUPPORTED VIDEO CARD
$35.00 OPTICAL DISC DRIVE (NEWEGG)
LITE-ON 20X DVD+R DVD BURNER WITH LIGHTSCRIBE BLACK SERIAL ATA MODEL LH-20A1L-06
$45.00 CPU COOLER (NEWEGG)
TUNIQ TOWER 120 P4 & K8
$105.00 HARD DRIVE(NEWEGG)
SAMSUNG SPINPOINT T SERIES HD501LJ 500GB 7200 RPM SATA 3.0GB/S OEM
$330.00 MONITOR (BESTBUY)
HP 22" WIDESCREEN FLAT PANEL TFT-LCD W2207H
$25 SHIPPING
$1560.00 TOTAL
Once again sorry for all the caps! All my prices are rounded and not 100% exact.
Questions:
1)Is the video card a I have chosen now better than my last choice? It is $20 cheaper and supposed to be the same card and is already OC.
2)What fans would you suggest to replace the case stock fans and the Tuniq Tower fan? I am wanting to make it run cooler. LED's would be a plus!
3)I am planning on buying everything from Newegg on or before the 15th so I can save the extra $30 off the P182 case. Is this setup good? Any possible problems?
$25 SHIPPING
$1560.00 TOTAL
Questions:
