yourdeardaniel
- Mar 20, 2004
- 1,905
- 0
- 0
good choice for CPU. Ultra-D doesn't support SLI unless you mod it for SLI (then you still have to buy SLI bridge for $20 ish), i suggest u just get the SLI board if you plan on using SLI in the now or in the future.
AMD-compatible Motherboards
Update DFI LANPARTY nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard - Retail
Model #: LANPARTY nF4 SLI-DR
$198.00 $198.00
this is a good 600watt PSU with 24pin and should be more than enough for your needs.
Update ENERMAX All in One Noisetaker Series EG701AX-VE SFMA(24P) ATX12V 600W Power Supply - Retail
Model #: EG701AX-VE SFMA(24P)
$179.99 -$30.00 Instant
$149.99
best air cooling for cpu is thermalright XP-90 w/ some 92mm Panaflo fan.
you only need 1 DVD burner. 3540 is good choice.
you might want additional DVD drive for reading. get the Lite-On LITE-ON Black IDE DVD-ROM Drive Model SOHD-16P9SBLK - Retail $19.99
$198.00 $198.00
$149.99
