Just finished ordering the last components of my new semi-budget computer, Final specs:
Athlon 64 3000+ 939
MSI Neo2 939 Mobo
512x2 Kingston HyperX PC3200
Antec Lanboy Case
Enermax 370W PS- Dual 12v volt (14A,13A)
BFG 6800 OC (Best Buy deal w/ Half life)
Harvest; CDRW, DVDROM, LCD, keyboard, mouse
Anyway, i was wondering if anyone had any good links for the first time builder as far as construction but also BIOS setup. And, solutions to common problems or things to avoid. Also, what other benchmark programs should i use to test the components of the systems? I know of Prime95, Sandra, 3DMArk, but have never used them. ANy other advice for the build are welcome!
Thanks
-Chris
Athlon 64 3000+ 939
MSI Neo2 939 Mobo
Antec Lanboy Case
Thanks
-Chris
