Originally posted by: ViRGE
RAM is cheap and helps with file transfer performance due to more available RAM for caching. A Conroe is a good fit if you ever decide to do anything else with your WHS box, and it's also a good idea if you ever plan on upgrading to the Server 2008-based WHS v2 (which I think just about everyone here is drooling for).Originally posted by: Stoneburner
Originally posted by: mmx
In the end,
I'll be using the e6300 cpu
Dell MB WITH 4 GIG RAM
2X 1.5GIG HD WD- new one came out connected to the MB
DVD/Rw
Gigabeat ethernet from MB.
This should be a pretty powerful WHS. Right? How to best use the systm and energy savings?
I think some are wondering why you need a "powerful" WHS. You need HD space, you need a good network connection. Conroe? 4gb ram? Probably overkill.
Usually these boxes are built with large but low-performing (read: cooler running) hard drives, so drive performance can be a bottleneck. RAM directly helps with writes by giving the server more room to cache things in before having to slow down the transfer to whatever the disk can do, and in certain cases it helps with reads too if what's being read is already cached (and hence you don't need to go hit a disk).Originally posted by: Stoneburner
Ram on the server? I'm assuming you're talking about transfers to the server? I would have assumed it's the computer doing the transferring that matters more.
In the end,
DVD/Rw
And when's 2008 based WHS coming? I'm just getting used to 2003 based WHS. So far it's good, though i'd like FULL remote access back office style. The console interface is okay. I need to learn the tricks though.
