Building a new system and have a few small questions.
Mar 13, 2005
112
Here is what I have to start with, and I have a small budget $500-$600 for the rest. The parts I will be bringing over to the new system:
Antec Solution SLK3000-B Black Computer Case
http://www.newegg.com/Product/Product.asp?Item=N82E16811129152
2 sticks WINTEC AMPO 512MB 184-Pin DDR SDRAM Unbuffered DDR 400
http://www.newegg.com/Product/Product.asp?Item=N82E16820161615
NEC 3520a dvd burner.
And a Maxtor 250GB Hard drive.
This is what I am looking to buy.
XFX PVT70GUDF7 Geforce 7800GT $294 shipped
http://www.newegg.com/Product/Product.asp?Item=N82E16814150108
AMD Athlon 64 3200+ Venice 1GHz FSB $160
http://www.newegg.com/Product/Product.asp?Item=N82E16819103535
EPoX EP-9NPA+ Ultra 4107 $105
http://www.newegg.com/Product/Product.asp?Item=N82E16813123236
XCLIO XClio 450BL ATX 450W Power Supply $51
http://www.newegg.com/Product/Product.asp?Item=N82E16817189003
$610
I won't be Over Clocking, and I probably won't be buying anything for a month so prices are sure to change. My main question is whether If buying that good of a graphics card is overkill with this machine. Would I be better served spending some of that money elsewhere?
Bonesdad
2,213
The graphics card won't be overkill...unless you only surf the web. Do you game?
Mar 13, 2005
112
Currently BF2, I guess what I mean by overkill is would I be better served getting a slightly worse graphics card and a slightly better processer.
cKGunslinger
16,408
57
I don't think your video card is being completely hamstrung by your CPU, if that's what you are asking. Most modern games are VPU-limited, so it would be rather hard to get an "overkill" video card with modern hardware. Maybe if you were running a slower 754 Sempron or Celeron, but not with the 3200+ Venice, I don't think.
