I've been looking around at various MIS, Soyo, Atus boards and I'm just getting confused. I want to build a machine, my first, and make it a recording pc. I want to get a bundle, 1st preference would be AMD Athlon, then Intel for the chip.
I need to save some money but really need to get a good start.
This is what I was thinking of but think it's a little expensive, maybe I can get some advice and pros and/or cons to different setups?
Case:
D15-1002 :: Diablo Tek Black Demon ATX Mid-Tower Case with Front USB Ports
http://www.tigerdirect.com/app...41440&sku=D15-1002
Bundle:
MBM-KT600-XP2900 :: Soyo KT600 Dragon v2.0 Socket A Motherboard and AMD Athlon XP 2900+ Processor
http://www.tigerdirect.com/app...p;sku=MBM-KT600-XP2900
Power Supply:
D15-1000 :: Diablo / 550-Watt / ATX / Dual 80mm LED Fan / SATA-Ready / Power Supply
http://www.tigerdirect.com/app...41436&sku=D15-1000
I also considered the MSI Neo2 Platinum. I've been told Tiger Direct is great but on this site I only read bad things. If anyone can give me direction I'd really appreciate it.
Thanks much.
Case:
Bundle:
Power Supply:
Thanks much.
