mxnerd
- Jul 6, 2007
- 6,799
- 1,103
- 126
OT...I thought those were Level 3's DNS? Does Verizon own Level 3?
(goes to look)...
It used to be long time ago. Don't if it's own by Level3 now.
(goes to look)...
but no AES256 and the SHA was actually 1
- to use a different cipher add the configuration option '--cipher CIPHER'
- supported ciphers are:
- AES-128: '--cipher aes-128-cbc' << recommended
- AES-256: '--cipher aes-256-cbc'
- Blowfish: '--cipher bf-cbc'
- No Encryption: '--cipher none'
- to use a different authentication digest add the configuration option '--auth DIGEST'
- supported digests are:
- SHA1: '--auth sha1' << recommended
- SHA256: '--auth sha256'
- No Authentication: '--auth none'
- to use differnet handshake encryption change the configuration option '--ca CERT'
- supported handshake encryptions are:
- RSA-2048: '--ca ca_rsa2048.crt' << recommended
- RSA-3072: '--ca ca_rsa3072.crt'
- RSA-4096: '--ca ca_rsa4096.crt'
- ECC-256k1: '--ca ca_ecdsa256k1.crt'
- ECC-256r1: '--ca ca_ecdsa256r1.crt'
- ECC-521: '--ca ca_ecdsa521.crt'
don't know sdifox's experience for running pfsense in VM
In the past few days, I did experience some difficulty with running pfsense in VM.
Like what I mentioned earlier about "Diagnostics-Edit" doesn't work in VirtualBox
Today when I tried to install TinyDNS package in pfsense VMware VM, either the package install halfway and stuck, or even if it completes the installation, after that, I can't even login into the pfsense at all.
I have tried several times, and it did the same. pfsense installation in a VM seems always causes some quirky situation.
I have never experience anything like this before.
Maybe it's better install pfsense directly on real machine.
IPVanish works but they only allow a 16 character password.
a password does not matter with OpenVPN as long as your client side is not physically accessible by anyone else. the OpenVPN client itself authenticates with both a master and individual certificate, passes unique keys, and encrypts based on config files or definitions your VPN service will provide, so the password you use only activates the login script nothing more.
I don't use a login name and password at all because I OpenVPN on a home computer I alone can access, and I'm on/off my VPN so often that I don't want to be bothered with yet another login request. besides even if some robber broke into my home and used my PC and VPN, what would the added insult of using my VPN really matter in the scheme of things. the point is the login password itself does not add any more protection to the VPN tunnel integrity, only whether a user sitting on your PC can activate the tunnel or not. at work where I use a pair of SonicWall boxes to hardware VPN a branch to a home office, I don't use passwords to activate that tunnel either, since it's impossible to form a tunnel anywhere else without those 2 boxes which are configured with insanely long mixed case alphanumeric certificates(255) and keys(2023) that even DARPA cannot crack or even deep packet inspect.
even if a person on another computer got your name and password, knew and configured his PC with the same config files the VPN provider gives by default when you sign up, he still could not login and use the service on your account because the VPN provider has a record of what certificates and keys it shares with each account, so your username/password would not match up thus your login information would be worthless to anyone else. this is why when you sign up with a VPN provider you need to notify him if you are using the same account on two or more devices since they must make allowances for that level of flexibility. so far the VPN providers I've seen will market by either one or up to three different devices per account.
I have it running in hyperv. Mind you I am using server hardware so much less driver issues. And I am not doing VPN and not dealing with PIA.
Upgrade the RAM in this: http://www.amazon.com/Intel-Fanless...p/B008KB5YCK/ref=cm_cr_pr_product_top?ie=UTF8
Found that pfsense 2.1 & 2.2 did support INTEL AES-NI !
under System - Advanced - Misc - Cryptographic Hardware Acceleration
OpenVPN
To take advantage of acceleration in OpenVPN, choose a supported cipher such as aes-128-cbc on each end of a given tunnel, then select BSD Cryptodev Engine for Hardware Crypto.
Similarly, if the system employs the VIA Padlock engine, choose an appropriate cipher and select VIA Padlock for Hardware Crypto.
Nothing needs selected for OpenVPN to utilize AES-NI. The OpenSSL engine has its own code for handling AES-NI that works well without using the BSD Cryptodev Engine.
IPsec
IPsec will take advantage of cryptodev automatically when a supported cipher is chosen. For AMD Geode systems, this is AES with a 128-bit key length, and for Hifn card users, 3DES or others known to be accelerated by the crypto card.
For AES-NI acceleration, use AES-GCM on both sides of the tunnel. (Requires pfSense 2.2)
*) Support for new and upcoming Intel processors, including AVX2,
BMI and SHA ISA extensions. This includes additional "stitched"
implementations, AESNI-SHA256 and GCM, and multi-buffer support
for TLS encrypt.
This work was sponsored by Intel Corp.
[Andy Polyakov]
Finally connected the PC with pfsense on it to my network, made a few changes to the settings and rebooted the modem. Received a connection and was tweaking. Started watching TWC app on the Xbox 360 and hard crashed pfsense. I'll connect to the IPMI port later to see if I can see what crashed on it.
Back on Asus router for the moment.
Edit: Connected monitor and console was still up with no error messages. Know that it had not rebooted because I could see the console messages from the previous logins to the GUI. Strange. Couldn't get anything from the GUI and no Internet. Still not rebooted. Will play with. Need to get the IPMI SuperMicro management software up so I can do all of this without a monitor/keyboard attached.
You just needa browser no?
Run memtest86 on the new build to test RAM first.
Plug & unplug ethernet cable to make sure you assign the correct port to LAN and WAN since you have 4 ports.
Edit #4: I think the WMC issue is the fact that I had the Asus router assign a static IP to the HDHomeRun Prime units and not the pfsense box. I've figured out how to use the hdhomerun prime utility to manually set permanent static IP address. Hopefully, that will resolve the issue of switching out routers and the WMC network.
