- Nov 9, 2007
- 5
- 0
- 0
I too just bought and put together a new rig. GA-P35-DS3L, E6550, 2x1GB OCZ Plat. memory, 8400GS, Cooler Master eXtreme 650W.
Two main problems:
1) It boots to post, then windows loading and crashes at the same point everytime.
2) When i try to go into setup to mess with BIOS, my keyboard (usb powered) doesnt do a damn thing sooo basically im helpless
Im thinking maybe i could use a PS2 keyboard and see if i can try to reset bios with that.. hopefully. Also, Im thinking it might be the ram. I know the OCZ platinum needs 2.1 v to run properly, but once again i cant get in to do anything. Any advice or suggestions would be very helpful.
Two main problems:
