Cerb
- Aug 26, 2000
- 17,484
- 33
- 86
Iff you want to go that route, look at Lenovo TS140 and TS440 systems on Amazon, from Computer Upgrade King, and add your own drives and RAM (or use the 4GB typically included). The TS140 lacks much internal expansion for drives. You can get caddies for the TS440 for around $15-20 per, if you look around Amazon and eBay (that's the main negative of such servers from big OEMs). You can add DAS if you want to go bigger later.I could go lower through a box store... but the price I get on the i3 would get me Celeron-ish ranged CPUs at a box store.
I'm not above going ECC memory. The reason I looked at server motherboards was feature sets such as dual+ ethernet ports, more SATA ports, SAS ports, etc.
If you're not going to be using SSDs, just make sure you have enough PCIe bandwidth for the drives, when it comes to adding controllers. Used LSI cards that can be flashed to HBA, or otherwise configured as HBAs, or that are only HBAs, are good bets, since they tend to be x8, which offers tons of bandwidth for spinners, especially when limited by 1Gbps for file data. With a little researching, you should be able to find 8-port cards (may need break-out cables) for under $100 any day, and under $50 if you spend more time and effort.
For a home NAS, 4GB should work, and 8GB will be bordering on overkill (4GB might even be overkill, actually).
As already said, dual NICs are going to be difficult to make use of, and IMO won't be worth it. To make good use of it, you'll need to either have multiple VLANs, or multiple computers able to team them, with switches to match.
Here is an example. $300, with more CPU than you need, but just needs drives and caddies for up to 4, with room for 4 more (needs Lenovo 03X3703 and 03X5999). Not super duper cheap, but quite good compared to other ways of building with hot swap, and cheaper than any other big OEMs.
Another way would be to just get a Fractal Design Node case, and fill it up with non-hot-swap drives, with a Pentium or i3. If you want ECC, the motherboard is what will get you, there, cost-wise.
 Facebook
Facebook Twitter
Twitter
