- Feb 21, 2014
- 95
- 0
- 16
Also, I need to find some 1.5" - 2" round stickers for the fans. Any ideas? I wonder if I should just buy some sticker printer paper and make my own.... oooo, I might like that idea.. and I guess I have some time to kill.
Also, I need to find some 1.5" - 2" round stickers for the fans. Any ideas? I wonder if I should just buy some sticker printer paper and make my own.... oooo, I might like that idea.. and I guess I have some time to kill.![]()
Ok, a little bit of an update.
So, yesterday at work I thought of a nice little mod I could add to my system. Let me run it by you guys.
As the NZXT H440 has no front 5.25" drive bays, I'm very limited to what I can do as far as fan control. So, I was thinking, got the current rating for the GT 1450's off of the net, and popped into the local electrical supply store. I picked up a few voltage regulating reducers, and ordered a rocker line switch. By installing the voltage regulator, I can safely reduce the supply voltage to the fans, slowing them down. I picked up a 10V, 8V and a 6 V reducer, to try some different speeds and test the sound and airflow. The 8V reducer seems to work the best for me.
I am also going to run the voltage line through the switch, and wire it so that you can select either the reduced voltage (silent running) or full 12 V (for stress testing/ gaming) by flipping the switch.
I haven't seen this kind of mod done before, but the big reason for that I'm sure is that lots of times there is a drive bay slot for a controller. How's this sound for a solution, has anyone seen this done before?
Also, today I mocked up a design for my GPU block Backplates... just have to get the paint to do what I need it to :hmm:
Anyways, here is what I'll be going for, all done in plasti-dip.
Hello again, and yes I am still alive, and so is this build... though still slow at the moment as I am still (yes, still) waiting on the case.
But that hasn't stopped me from getting things prepped and on the go.
This weekend I had lots of time to dig into a few issues. First, the rad prep and cleaning of new loop components. Second, getting my SLI setup linked and working. (Which was fairly big issue, as I am using the Skynet Bios' and 2 different cards, will explain below)
I started out with the loop flush and prep. I pulled one of my lengths for Primochill tubing out, and rinsed the 2 rads, res's and tubing with pure distilled. I then hooked it all up in a long loop, refilled with distilled and added some of the Loop prep that comes with the LRT, and a few drops of dishsoap. I am running this for a few hours each night, getting everything good a flushed out, (I dump the res's each night to pull out anything that settles.)
...with the custom red LED lighting in full effect...
I do mine in the sink!!! Is that 1/2 ID...looks big.
You bet, 1/2 ID by 3/4 OD. Much nicer to work with this tubing than my older stuff. Decent bendablility, and no kinking. :thumbsup:
I feel your pains Sims, I've been waiting for almost 8 weeks now on a backordered GPU block from Performance PCS, and I don't feel like assembling and cleaning parts of the loop without having everything in place first. I still need to get around to the physical mods of my case to make everything fit but the wait is annoying and I'm starting to lose interest in the case for now since all the planning and what else could I fit in is getting out of hand
This is going to be my first build on water so do you think the amount of prep/cleaning you did for your radiators is necessary or is this just something you're doing while you wait?
