Ill keep my eye on this one.
I wish I had your solid tube skills...could really use them!
...Let me know how the lutro0 stuff works since while I like MDPC's stuff and how well it performs, but the cost for a good amount of the stuff is pretty hefty for sleeving.
/me quietly pinching own nipples in the corner
Nice stuff, I'm running a stock Phantom 630. I do have a question though, after totally disassembling and modding/painting this case and then reassembling it is it really an NZXT case anymore? Isn't it now really a Tweakin' case made with some NZXT parts?
Great pics Tweakin'! Thanks for this post, as I was wondering myself how the hard it would be to access this and separate it. :thumbsup:
FWIW, the second one gets my vote.
The white rivets look good too. Nice attention to detail with that. :thumbsup:
Name change due to design change eh? 😛
I also like the second more as the white backplate seems to come on a little strong, but that is how it seems in its naked environment. A picture with a motherboard installed might change the overall appearance but I don't think you can go wrong with the back as black and then using white sleeved cables to add a little accented touch here and there.
...How/where do you intend to mount your pump for this build?
