1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming / Video encoding.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1,300
3. What country YOU will be buying YOUR parts from.
US
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Amd, Ati, Corsair.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Cooler master sniper case, Corsair 850hx, 2x Gentle Typoon 15 fans (for corsair h70), Windows 7 64bit, Monitor 25.5, Mouse, Keyboard.
6. IF YOU have searched and/or read similar threads.
7. IF YOU plan on overclocking or run the system at default speeds.
Overclocking cpu to 4ghz, Gpu 900-1000.
8. What resolution YOU plan on gaming with.
1920x1200
9. WHEN do you plan to build it?
Either half now and half november or all november.
Well im rather sure what im going to buy. just here to see your output on if i should begin to purchase now or wait untill november for possible deals / new possible parts?
heres what i have,
cooler master sniper case
corsair 850hx psu
gentle typoon 15 fans
heres what im planning on purchasing,
1055t 95w
gigabyte 890fx ud5
2x 2gb sticks of g.skill eco - 1600mhz 7-8-7-24-2N
corsair h70
g.skill or corsair 120gb sandforce
western digital black caviar 1tb
msi lighting II 5870 / or possible 6 series card if its out in time / in the 400-450 price range.
lg bluray disc burner.
so i could purchase the cpu/mb/ram/wd 1tb next week, then the corsair h70 in begining of october then ssd/gpu/bluray burner come black friday or i could wait and purchase it all on black friday.
main reason im asking is because i want to see if you guys think any newer parts will come out in that time peroid, pretty sure i read the amd 6 series gpu's will be out, but since i read its confirmed bulldozer will be am3+ only i didnt know if we could expect am3+ motherboard's by november.
also im willing to look at suggestions towards the build itself.
thanks for reading.
$1,300
US
Amd, Ati, Corsair.
1920x1200
heres what i have,
corsair 850hx psu
1055t 95w
gigabyte 890fx ud5
corsair h70
thanks for reading.
