Build for friend
Wheelman56
203
ASUS A8N5X Socket 939 NVIDIA nForce4 ATX AMD Motherboard - Retail $79.99
AMD Athlon 64 4000+ San Diego 2000MHz HT Socket 939 Processor Model ADA4000BNBOX - Retail $336.00
ZALMAN CNPS7000B-CU 92mm 2 Ball Cooling Fan/Heatsink - Retail $43.99
XFX PV-T71G-UCE7 Geforce 7900GT 256MB GDDR3 PCI Express x16 Video Card - Retail $329.00
OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model OCZP4002GK - Retail $191.99 ($50 mail in rebate)
ASPIRE ATX-AS520W BLACK ATX 520W Power Supply - Retail $56.99 ($10 mail in rebate)
Seagate Barracuda 7200.8 ST3250823AS 250GB 7200 RPM Serial ATA150 Hard Drive - OEM $86.00
XION XION II XON-101 Black Steel ATX Mid Tower Computer Case 450W Power Supply - Retail $70.99 ($15 mail in rebate)
LITE-ON CD Burner Black IDE Model SOHR-5239V BK RT - Retail $20.99
LITE-ON Black ATAPI/E-IDE DVD-ROM Drive Model SOHD-16P9SV - OEM $18.99
Amigo AMI-CA58 56Kbps Internal Modem - Retail $5.99 (Yes, he's having me build this and he's on 56k...)
$1,300.20 Shipped
Pretty sure everything works out, but if I made some stupid noob mistake then let me know.
pkme2
3,896
Or, if you on a really tight budget, a Fortron or Enermax will do. Otherwise if you got the bucks, Seasonic.
Wheelman56
203
Is the power supply I chose not good enough?
Its 520W and it has 32A on the 12v rail I believe.
Howard
47,986
11
It might be, but who knows how long it'll last?
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
The Aspire might work, but they have a reputation for failing. Why risk it. Get a PSU with a better reputation for dependability. I say Fortron, Enhance, or Seasonic.
JEDIYoda
33,986
3,321
Most PSU that are shipped with the ASPIRE Cases are OKIA brand and as was stated earlier...It might be, but who knows how long it'll last?
I will tell you that for several years i used the OKIA with my ASPIER cases and had no issues.
Still i would probably get a different PSU using all that new equipment!!
No PSU manufacturer is going to pay for parts that get ruined or fried if your PSU screws up!!
RussianSensation
19,458
765
I'd go with 3700+/3800+ cheaper cpus. The difference in performance is minimal.
ARCTIC COOLING FREEZER PRO 64 - $25
Just as good, if not better.
OR ZALMAN CNPS7000-CU - $26
FSP Group (Fortron Source) AX450-PN - $51
- you are getting a tower but overpaying for the included power supply. Maybe find a tower without the psu like CoolerMaster Centurion, etc.
I'd get a DVD burner instead. I have a dvd rom and a dvd-writer and I haven't burned CD to CD or DVD to a DVD in 2 years. Either way a DVD writer is not much more $.
OhioState
1,555
I have to agree i own this case first thing i did was pull out the psu .
Tarrant64
3,203
As mentioned, be sure you don't go cheap on the PSU. Some people I guess wouldn't think so, but it is essential to keeping your rig running smooth. A faulty PSU can cause some serious problems in the future.
The build looks pretty sweet! Good luck!
Wheelman56
203
450W, is that enough? Also, I don't really know anything about the dual 12v rails, is there any difference between a normal PSU?
Wheelman56
203
I was also wondering if my Motherboard and RAM were compatible because I couldn't find anything on OCZ's site for the motherboard I choise. I think I might change it to an DFI LanParty nForce4 Ultra board, but I'm not sure yet. Any input would be great.
Tig Ol Bitties
305
Your RAM and mobo is fine, nice RAM choice btw. The Fortron PSU is more than enough to run what you're running and is way more reliable than that Aspire. Get a Centurion instead of that Xion, no hasles with that PSUs and I think better airflow
EDIT: your cpu chioce is not worth it. Either a 3700 single core or a 3800/4200 dual core would be sufficient
Ionizer86
5,292
Switch the CPU to either Venice 3200+ to save money or to 3800+ or Opteron 165 for dual core. There's supposedly a sale on Monarch right around now for a ~$280 165.
Don't buy a 7200.8. Get a 7200.7 or .9 instead, as the .8's have reliability issues. I think your .8 is rather expensive too, as I got my 200GB 7200.7 for $30 and all my rebates came quickly.
Swap your opticals for one DVD burner. A dual layer 16x burner ought not cost much more than $40.
Buy cheaper ram. Save the pocketed money for broadband :)
