Hey THG. I have come back for some more opinions from this community! My bro wants to build a computer and I was wondering what I should select as far as parts.
Approximate Purchase Date: ASAP
Budget Range: $800
Usage from Most to Least Important: Emulators (with the most demanding being the PCSX2 Emulator), making servers, general use
Parts Not Required: OS, KB, Mouse
Preferred Website(s) for Parts: microcenter, newegg, amazon, us ncix, superbiiz, ebay
Country: Frisco, TX, USA
Parts Preferences: by brand or type: Intel CPU
Overclocking: Yes
SLI or Crossfire: No
Monitor Resolution: 1680x1050 for now; going to be 1920x1080 soon
Additional Comments: Quiet, but efficient.
So far, here is what I have been suggested from another forums:
[quotemsg=2607672,2,309238]
This build down below doesn't over clock but after experiencing SB and seeing the benches on IB in regards to gaming and over clocking I don't see the benefit all that much. If the budget was bigger than ya np for adding the 3570K but with that budget I'm thinking that $$ could go towards a vid card.
http://www.microcenter.com/single_product_results.phtml?product_id=0348766 $59.99
Antec High Current Gamer Series 520W ATX Power Supply | 80 PLUS Bronze and Active PFC
4GB of RAM works fine and $17 saved is $17 towards a vid card, case, etc... He can always add another set later on for a total of 8GB if he ever feels the need.
http://www.microcenter.com/single_product_results.phtml?product_id=0382074 $22.99
Crucial 4GB DDR3-1600 (PC3-12800) CL9 Desktop Memory Module Kit (Two 2GB Memory Modules)
http://www.microcenter.com/single_product_results.phtml?product_id=0382101 $39.99
Crucial 8GB DDR3-1600 (PC3-12800) CL9 Dual Channel Desktop Memory Kit (Two 4GB Memory Modules)
http://www.microcenter.com/single_product_results.phtml?product_id=0382892 $15.99
Samsung 22X DVD±RW Burner with Dual Layer Support - OEM
http://www.microcenter.com/single_product_results.phtml?product_id=0388579 $149.99
Intel Core i5 3450 3.1GHz LGA 1155 Processor
http://www.newegg.com/Product/Produc...me=Intel%20B75 <---- B75 board gives him PCI-E 3.0, front 3.0 USB header, etc...
http://www.asrock.com/mb/index.asp?s=1155 <----- Asrocks line up of B75 boards.[/quotemsg]
AND
So far, here it is:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=13328589
http://www.microcenter.com/single_product_results.phtml?product_id=0387627
http://www.microcenter.com/single_product_results.phtml?product_id=0388577
The 120mm fan stays because I want him to have a cool system, and what better way than a push-pull config.
What do you guys think? Thanks!
Budget Range: $800
Overclocking: Yes
AND
So far, here it is:
