build advice
1. Don't use the workshop, except for mods that are only available there.
2. Use either NMM, or Mod Organizer, but mods that require SKSE must be installed manually, if you use Mod Organizer (Mod Organizer tries to keep your Skyrim folder free of mods, but that obfuscation messes up SKSE mdos, even some that don't have DLL plugins).
3. BOSS: http://www.nexusmods.com/oblivion/mods/20516/?
It helps sort out load order, and find files that need cleaning. Generally, mods that are still supported don't need cleaning, but some older mods, prior to effective and stable TES5Edit, do, and it's not a bad idea to clean the official expansion ESMs. Don't clean the unofficial patches, though, as their dirty edits are bug fixes. A few other mods, like the guard dialog overhaul, also shouldn't be cleaned (but BOSS makes a note of the known ones). Installed into your Skyrim folder, it will scan the mods, and then open a browser with the log.
4. Yes, worry about load order. It's been a problem since good ol' Morrowind. Install order can matter for conflicting mods, but only those that need to overwrite another's files.
should i install manually if i can? what about 2k skyrim hd?
downloaded boss
what about content or dragon mods
have any good suggestions
This discussion has drifted extremely far from hardware topics, I'd suggest making a Skyrim mod thread over in PC Gaming and taking that part of the discussion over there.
mfenn
General Hardware Moderator
This discussion has drifted extremely far from hardware topics, I'd suggest making a Skyrim mod thread over in PC Gaming and taking that part of the discussion over there. mfenn General Hardware Moderator
was already thinking about that. although these should be the last questions i need to play skyrim specifically the enb question. just need to know if project enb is compatable with enb .245. it is made for enb .221
will think about making a pc gaming thread over there after this.
thankyou
That's the thing, it seems like Cerb is the only person who peruses this forum that knows jack about Skyrim mods. I sure don't. You'll get more and faster responses over in PC Gaming.
if i wanted to make a thread on any of the following topics where should they go?
the future of enthusiast and hpc
the future of amd
21st century space
they all seem like they could go in the discussion club but it seems like not very many people post there. space could easily go in off topic. but the other two i am confused as to where they would best go.
CPUs & Overclocking or Video Cards & Graphics depending on the focus. Be warned, this type of thread usually brings the trolls out of the woodwork.
more about everything the company does. hsa, cloud, hpc, embedded would all be covered under this topic.
thankyou.
created a thread in pc gaming. please leave this thread unlocked so if i have a problem with my computer i can use this thread again.
I was just about to mention that other forum, if he made more SKyrim posts. It will keep the thread near the top for something unrelated to GH.
<- last post
