Budget Home Theater ideas
Report back with your thoughts once you get everything set up.
Did you buy speaker wire already?
I have my computer in another room hooked up to my receiver with a digital coaxial cable for sending audio.
You can get fancier if you want, but this works fine for my purposes.
Some people use their DVD player / Blu-ray player as their CD player. Some people (who have spent a lot on their system and feel that the quality of their disc player is the limiting factor) end up buying a dedicated CD player.
Based on where your system is now, I'd say you probably want to get a blu-ray player that does everything.
Thanks Yoyo. I haven't bought speaker wire, component or coaxial cables yet. Do you have any suggestions of where to buy them?
Thanks for the disc player advice. I haven't started researching what would be a decent player. Perhaps a refurb may work well in my situation...
I do hope I like the Onkyo. I will definitely let you know how it sounds whenever I get it setup.
kazaam, Amazon still has the Onkyo for $317 if you decide that's what you want.
http://www.amazon.com/Onkyo-HT-RC160...dp/B0028AD7BE/
Monoprice cables work just fine and they're very affordable.
New blu-ray players are getting pretty darn affordable too now.
