- Oct 13, 2012
- 49
- 0
- 0
I was messing around with the voltage of my CPU, an i5 3570k, to make the voltage lower. I do not overclock but it was still too high. Everything was fine until I followed the tutorial and pressed restore optimized defaults in the BIOS so I could start from scratch. I then looked at a tutorial on how to lower voltage. I followed every step, but now I can't boot into Windows Ultimate 64 bit. As soon as I get to the windows logo I get BSOD. My computer has been working fine for 7 months and I've tested the memory before, so I'm sure it is something with the BIOS. I don't know if when I clicked restore optimized defaults it changed everything or just the CPU configurations, but I'm thinking it changed everything.
I really don't know how to change it. Is there some things I should change in the BIOS to see if it would work? I'm thinking I disabled something when i clicked restore optimized defaults. I changed everything in the AI Tweaker menu (CPU menu) to what it was before ( voltage and disabled and enabled settings) so I'm pretty sure the problem lies somewhere else in the BIOS, I just need to know what to do. I remember when I first built my computer I had a problem loading into Windows but I'm blanking out on what I did to fix it. Is there some things I should enable and disable in the BIOS to see if it will boot?
From clicking restore optimized defaults, did that somehow mess up my installation of Windows 7? Does that mean I have to install it again? I don't think I have a repair disk. If I have Windows 7 64 bit and then try to install it again will it work and not delete anything? Is that basically what a repair disk is? I'm really new to this stuff, sorry for asking so many questions.
Any help is appreciated.
- ASUS PZ68-v
- 8 GB of RAM
- i5 3570k CPU
- Intel Graphics 4000
- 850 W Power Supply
