Originally posted by: Wadded Beef
(Question numbers are as they appeared on the test)
4. Which of the following statements about an ATX system is false?
a. Components on the motherboard are arranged so as not to interfere with each other.
b. The power supply fan blows air out of the case.
c. There are fewer wires used to connect switches and lights on the front of the case.
d. The position of the power supply and drives inside the case makes connecting them easier and makes it possible to reduce cable lengths.
answer is B on the answer key.
I put C
reasoning: teacher says the power supply fan blows air out of the power supply not the case. i say thats bs because the air the psu blows out is coming from inside the case, for it to be false the air blown out of the psu would have to come from outside, seperating it from the case's airflow.
25. Which is NOT a typical speed of a motherboard?
a. 100 MHz
b. 133 MHz
c. 166 MHz
d. 400 MHz
answer is C on the answer key.
I put D
reasoning: what i'm saying is the ACTUAL fsb speed is 166mhz on an athlon xp system, the "400mhz" bus speed either comes from old quad pumped 100mhz p4 systems or an athlon xp3200+ etc... 400mhz either means 100mhz x4 or 200mhz x2
26. Which type of expansion slot is used for a video card?
a. PCI
b. AGP
c. ISA
d. All of the above.
I put D
reasoning: I've HAD pci video cards, and i've seen isa video cards.
29. The CMOS configuration chip ____.
a. contains information about how memory is allocated
b. retains its data when the computer is turned off
c. contains information about the computer's hardware
d. Both A and C
answer is D on the answer key.
I put B
reasoning: while a and c are true, b is also true when you have a good cmos battery (which you should) and it seemed like the simplest answer to me.
I got a few more wrong on the test, but I know why I got those wrong. These four questions are very "iffy" to me and a few other students in the class...
