Brother locked his key in his bedroom.
I've found for cheapy locks that pretty much any piece of flat metal that fits into the keyhole can be used to open the door. See if you can fiddle around with it using another one of your keys, might work =P
If you have a drill- drill the lock out and buy a new knob, that will be the easiest and the least ammount of damage. You can get a new doorknob for <$15.
Originally posted by: PingSpike
You could also try using your adamantium claws to cutout the locking mechanism in the doorknob.*
*Note: Requires you to be Wolverine.
BEST Suggestion so far :thumbsup:
give it a good kick
get a big screw drive and a hammer, place screw driver in key slot and bang it out
credit card might work
I vote for knocking the handle off and disassembling the lock. Replacing it will be alot cheaper than having a locksmith come out.
