Then they could have set the turbo to 5 GHz, so it could peak at that for a few milliseconds before starting to throttle. And you would have said it maxes out at 5 GHz. Come on, get real.It maxes out at 2.6GHz.
It's at 1.1 GHz, and that's not sufficient for a MBA laptop. It's good enough for tablet duty though.
Believe it. Apple wants a fanless Retina MBA, and this is the only option available to them at the moment. Apple hasn't merged OSX and iOS yet so A8 isn't an option.
Edit: Or they could use Airmont, but that's not coming out until next year, and the rMBA is coming out this year.
how are you getting those estimates?
Have a look at ATOM Z3770 (4W TDP) vs Core i5 4202Y (11,5W TDP). The ATOM is close to 70% the performance of the 11,5W TDP Core i5.
Im expecting the new 14nm ATOM to be very close to 80% or more(CPU) than 14nm Broadwell-Y at the same TDP.
Also, Haswell 11.5W TDP SKUs are priced at $280, ATOM is priced at $35. That is 8x times the price for ~30% more performance, ouch
Yes, but the single threaded performance of Atom is much less than 80% of Core's.
Source?Krzanich's statements of the perf ratio between Core and Atom)
Compared to Airmont?iGPU perf should beat everything else on the market. It's CPU perf that may not (Logan 64bit).
Starting at $600 means Core M's price isn't low enough for something like an iPad Air or an Android tablet.
Source?
The IGP of Broadwell-Y and Cherry Trail will be the same.
http://blogs.barrons.com/techtrader...ded-foundry-biz-new-broxton-sofia-atom-chips/
There is too much uncertainty with regard to the ratio of Broadwell-Y and Airmont, it would be logical that Intel would be concentrating on keeping the ratio the same. Otherwise then we would have to compare Airmont to Broadwell-U, and the ratio is significantly higher than 2x, for single-thread.
I'm optimistic about Logan-Denver, I think that they may have a chance even if Intel has years of experience on them.
Apologies for being sceptical, but this does look a little bit like a hangover from their previous strategy of trying to stay with really high margin chips and ignoring atom.
If you compare this vs the 14nm atom then they'll be on the same process of course and apparently being given similar levels of attention in terms of design. Meanwhile atom is specifically meant to run in this sort of power budget while core is really being pushed.
A priori I can't see why you wouldn't expect the atom to end up better. Massive die harvesting or something?
Bigger single thread performance for this of course.
Looks great. Also: "The 5Y10 supports a configurable TDP feature, which allows it to run at lower 4 Watt TDP." I wonder if there's any other difference between the 5Y10 and 5Y10a. Also a bit unusual names.
These processors should be a lot faster than any ARM SoC.
I wouldn't call that so easily. Apple A8 could be a game changer. TSMC 20nm brings a full shrink with 1.8x - 1.9x transistor density increase. Apple can easily double the CPU core count and clock them low enough to fit the 5w TDP. Four Cyclone cores clocked at 0.8 - 1 Ghz and with dual core turbo upto 2.0 Ghz should give this Broadwell M a run for its money. Also Apple could be integrating the PowerVR Series 6XT Rogue GX6650 which is expected to compete with Tegra K1 in GPU performance. Intel's graphics is not known for efficiency. Underestimate Apple at your peril. :biggrin:
http://www.anandtech.com/show/7793/imaginations-powervr-rogue-architecture-exposed/5
http://www.imgtec.com/news/detail.asp?ID=867
Die size won't really be the problem, but worse yields + much higher wafer costs + only ~1.3x lower power consumption would make such a chip expensive and power hungry. There's no way Apple could ever make a quadcore Cyclone or even more power hungry architecture with a 50% higher clock speed fit within a planar 20nm ~5W power envelope. Even your 1GHz base clock wouldn't be so easily done as you say.
You say that Intel isn't know for its graphics efficiency, which I could understand, but you (and we) don't know anything about Gen8, except that it's one of the biggest Gen updates ever and the number of EUs has quadrupled.
