Ivy Bridge was the first architecture with a fully integrated voltage regulator (FIVR)
Haswell was the first.
Sandy Bridge -> Ivy Bridge = Huge reduction in average attainable overclock (over 500mhz), oddly enough coinciding with the introduction of FIVR!
Sorry, but that's incorrect. The thing that Ivy Bridge introduced (aside from an iGPU that was able to make games not look like complete crap) was 3D tri-gate transistors, and it overclocked worse than Sandy Bridge because Intel started using thermal paste to attach the IHS instead of solder. Ivy Bridge-E, which did use solder, overclocked to pretty much the same speeds as Sandy Bridge-E.
Broadwell (and probably the process as well) was likely tuned for reduced power use at the expense of maximum clocks.
