Bridge Builder...
iamwiz82
30,772
13
weird, i tried both download sites, same with both of them... Even stranger is the fact that 8-15 is in the directory, weird.
Damaged
3,020
Hmmmmm...I'm not sure what to say here. Maybe you have to build the bridge under a certain amount to "qualify" for the next levels? I don't know for sure as they came up for me after I successfully tested my level 7 bridge.
samarth
460
Anybody know of any programs similar to it.
This is a lot of fun.
Gets pretty hard after level 10. Still stuck on 11.
duragezic
11,234
4
I got the level1-15 in the /level/ directory but in the root bridge builder it just shows level01-level07.
I made my level 7 bridge at about $23600 which is under the $25000... you can't build over the max anyway right?
I wants me later levels.
edit- I just beat level 7 again except this time at about $21600 and level 8 now showed up. :)
Pastore
9,728
damnet... i am having a really hard time beating level 6... :( i suck
oh my god... i just beat level 6... and i just about sh!t when i saw level 7 :Q
StageLeft
70,150
There is a "bug" some of you should be aware of which seems to work like this:
If you're working on your bridge and you save it, then continue to work on that if you then test and finish it says "next level" but it doesn't seem to take you to the next level at all. The way to get to a next level is that every time you hit "test" it saves the bridge in that level...I suck at explaining but the basic gist of what I'm trying to say is that you never need to save a bridge, because each time you hit test it saves it, then when you want to come back to it go start game > level > and that bridge will be there. If you then beat it then you can go to the next level. IE: "TEST SAVES" are the only sort of saves that actually work to get you to next levels; all saved bridges do is let you play on that single particular level.
MajesticMoose
3,030
Anybody else check out the system requirement?
<< Keyboard recommended >>
WTF is that??? who deosn't have one?
m00se:confused:
Pastore
9,728
ok, how about we just get some screen shots instead of the .brg files... it would be much more convenient...
thEnEuRoMancER
1,415
TheManiac: great work on level 15!!! However, in order to get all cars across your bridge needs to be modified a little - it should be one 'square' longer on the right side and heavier on the left side so that all cars can jump over - not only the first one.
enginjon
659
Im stuck on level 13...... not enough money!!! I need more money!!!! (actually just need to be more efficient) I don't wanna look at a solution though...ahhhhhhhhhhh
Windogg
I've been through it once and then went through making me designs more &quot;lean.&quot; Plus it's fun as hell to see how much mayhem you can cause by removing just one support beam. :)
BigLance
1,206
I love this game too...
I found that the way to win is to build to the bottom of the water even if there isn't any &quot;recommened&quot; places to hook to ! Works great !
