"breaking in" a new cpu before overclocking
IcePickFreak
2,428
9
I'll boot stock, install the OS and drivers, etc. Once I'm sitting at what I consider a "fresh" install, I reboot and start OCing it.
Soulkeeper
6,736
156
i never keep a cpu at stock speed for more than 10min or so (enough time to mess with the bios settings a few times)
i break them in at higher speeds :)
BonzaiDuck
16,630
2,026
With silly-cone/metallic combinations of components, the rule that I always understood was:
"Infant Mortality: If it's gonna fail, it will fail in the first 72 hours."
So with building a new system, I'd at least run it 72 hours -- before or after Windows install -- at stock settings. Or you could test your memory for a day's time with MEMTEST86+, then install the OS and run at stock settings for a few more days.
But this just addresses hardware failure so that if such occurs, you can get your RMA# and resolve it post-haste.
On the OC angle, you could be pushing your luck unless you research voltage and heat tolerances of the manufacturers for CPU, RAM and motherboard. But if their QC is worth anything, the upper ranges within tolerance or at tolerance should be safe.
