brass knuckles
Atheus
7,313
Originally posted by: eldorado99
I don't know why I know this but if you hold a combination lock in your hand putting the lock loop over your middle finger and locking it and holding the combination part securely in hand.
Sounds like a really stupid way to break your own hand.
Originally posted by: MX2times
Again, mace and pepper spray should be what you consider.
If you can get cs, then fine, but normal pepper spray is pretty useless. And sprays are easily dodged in any case.
MX2
18,651
If you say so. They make cans of that stuff that are small ebough for a pocket but when discharged you can cover some ground and soak someone from head to toe quickly, and at a good distance.
bradruth
13,479
Originally posted by: lightweight
DC Metro area. I don't even think off duty cops can carry them.
Why would they? It would be better to carry an ASP, OC, or, obviously, a firearm.
jlee
48,518
224
He was referring to firearms.
lightweight
473
I was talking about firearms.
bradruth
13,479
Oh, my mistake. Refer to the Law Enforcement Officers Safety Act of 2004.
UncleWai
5,701
68
How about pepperspray and then some brass knuckles action? Sounds like a win-win situation.
MX2
18,651
Just a quick google and i found this...
http://www.copsplus.com/pepperspray.php
I might grab one of these that I can keep in my coat pocket.
When you get it, have someone spray you with it while you try to attack them, you will see its effectiveness;):p
lol :thumbsup:
SampSon
7,160
I have a couple sets, I got them from the local flea market, and one set from one of thoes shady NYC knive stores back in the early 90s.
OS
15,581
fry's sells pepperspray for $5 a can for the nerds that need protection :D
