Lifetime warranty on pads means I ride them as hard as I fucking can. Only takes 30 minutes to swap them out.
You got lifetime rotor warranty too?
I really don't worry/think about it. Brake as I need to.
i don't ride my brakes.
i downshift.
where's my cookie?
Engine makes car go. Brakes make car stop. Use correct tool for job. :awe:i don't ride my brakes.
i downshift.
where's my cookie?
Light and long, as you put it. I'll generally down shift for compression braking, and then apply the brakes to come to a stop.
yea I do this too, but I'm not sure how effective this really is.Any time I have to brake a bit harder (going down hill into a sharp turn, for example) I generally take my foot off the brake for a short time every few seconds in hopes that it'll allow the rotors to cool down a bit.
Since I don't have a tach I don't like to downshift.
Depending on the motor that might not be as good for your car as you think.
Brakes are extremely cheap and easy to replace, I'm fairly hard on them and my front wheels turn black in no time..
