Brake noise when stopped (light pressure on brake pedal)...
mvbighead
3,793
Car is exhibiting a chirping sound when stopped. Recently replaced rotors and brakes, and the same sound was occurring before and after the replacement. Brake fluid is topped off. Can't think of any other reasons, so figured someone here might know.
Jeep GC 2000 4.7l V8.
cprince
963
wait..you're hearing the noise AFTER you had stopped? Might be an old/loose belt or something.
mvbighead
3,793
Precisely, only when stopped. If I feather the pedal a bit, it usually chirps or a little chirpy groan.
cprince
963
sounds like it could be the booster leaking vacuum. Does your engine rpm change when you feather the pedal? If not, I'm thinking it's just the brake pedal linkage needs oiling.
AMCRambler
7,714
31
Chirping? Best guess, I'd say a belt. If it makes the noise when the car is stopped and changes when you let off the brake and the car rolls I'd say probably the serpentine belt, the alternator pulley or a belt tensioner squeaking. If it changes pitch when you move your steering wheel back and forth, power steering belt.
mvbighead
3,793
Well, here's the thing... the noise only happens as I feather the pedal, but not so much as to allow the car to move. Basically instead of having the pedal pushed halfway in, I have it pushed about 1/8 to 1/4 of the way in, and there is a sweet spot somewhere in there. Some times it is a simple chirp... if I find the sweet spot and hold it there, it can be a long, drawn out chirp. But again, at no point does the vehicle move. The chirping is directly relational to where I have the break pedal pushed in, which doesn't make me think it's a belt, though I can't really say for sure.
At this point, cprince's suggestions seem likely... especially the brake pedal linkage business.
One last note, if it aids in the cause, is that when I checked the fluid, it was full. I haven't had to add any fluid yet, which, as far as I know, would suggest that it isn't leaking fluid anywhere... though that could be a poor assumption as well.
Thanks for your suggestions thus far, and keep em coming.
JCH13
4,981
66
Every car I've driven has made a weird noise like that just as the brakes are starting to slip an imperceptible amount. I wouldn't worry about it, I think it's just the brakes talking to you.
mvbighead
3,793
Thanks for the reply.
I will say this, sometimes (every day or so), the noise goes completely away. But it generally can always be made at some point. Essentially, it doesn't make the noise every time I press the brakes, but odds are it will (about 50/50).
Sep 7, 2009
12,960
+1, vacuum leak of some sort. Hopefully it's a hose, but I suspect the booster itself. See if you can get someone to hold the pedal while you chase down the noise..
Mxylplyx
4,197
101
I had a cherokee once that had a vacuum leak in the booster so bad that it would stall the engine if I slammed the brakes.
mvbighead
3,793
My engine can idle a bit rough from time to time, honestly. In fact, the past few mornings or so, it has been starting and then basically choking (almost to the point it dies). I hit the gas a little and she fires right up.
mvbighead
3,793
Should've listened to you a long time ago.
Well guys, after getting down under there and fiddling with the pedal by hand, it does seem like the noise is coming directly from the brake booster.
I have checked the hose in the engine bay, and it seems to be in good shape. I am guessing that means I'll be buying a brake booster and replacing it in the near future. Hopefully that'll be it.
mvbighead
3,793
I should add that one thing that really makes me think it's the booster (specifically) is seeing how it has that nice big opening and it really seems like the sound is being piped into the cab of the jeep. Granted, I am certainly not as knowledgeable as some of you guys, so anything you point me to will be looked at.
natto fire
7,117
10
Yeah, I am going to say booster as well, or possibly something in the ABS circuit. Might try disconnecting the ABS fuse(s) and reproducing the results.
Most ABS problems occur during ABS events though, and a dieing motor or leaky accumulator have more of a hum, but it's always better to rule things out than add more variables, IMO.
mvbighead
3,793
One more point, I did have the engine off, key off, and pressed the pedal down by hand and it still made the noise. I would assume ABS is completely unpowered, and therefor should eliminate that as a problem, right?
mvbighead
3,793
Well, got tired enough of it this weekend and went and replaced the brake booster. Problem solved!
Only issue now is the pedal is not in far enough to trip the brake light sensor, which means that the lights would stay on all the time. For the time being, I have rigged an extension on the sensor so that it does get pressed, but am not seeing any way to adjust the arm on the brake booster.
Perhaps it is screwed in, and rotating it a few times will change the position of the pedal, and push the sensor without my extension. Any ideas on what I am missing? I have tried fiddling with the sensor, but I cannot seem to get it closer to the brake pedal arm.
LTC8K6
28,520
1,575
The switch is likely adjustable. Could be screw type, ratchet type, or 1/4 turn and pull type. You'll figure it out.
mvbighead
3,793
Well, it was a complete PITA, but I finally got it done. Ended up pulling the switch out and disconnecting it. Looked it over good and hard, and tried and tried to turn what appeared (to me) to be a screw adjustment. Trying hard not to break it, I finally gave up on that idea. I tried pulling the sensor with my finger tips, but no dice. I was pulling and twisting this thing a number of different ways, and felt like I was going to break it.
Finally decided, the hell with it, if it breaks, I'll run over to the dealership and buy one for 30-40 bucks if I do. I took an old hard drive mounting bracket (had a hole size similar to the size of the sensor switch) and hooked it to the switch and pulled hard. It extended out just and to my surprise, without breaking. Put it all back and everything is great.
Thanks for the help guys, much appreciated!
LTC8K6
28,520
1,575
That's the self adjusting ratchet type, I believe. You pull it out too far, and then let the brake pedal push it back in when it comes up.
