Originally posted by: ropeadope
Hmm, Pacfanweb said to move left and torytime said to move right...now I'm confused
- When people said move a board over do they mean the dots where you start from or the actual boards in the floor? I can't move much more left though or I'll be bumping into the ball return machine or be almost in the other lane.
I don't know why anyone wouldn't bowl a hook ball, it gives you a much better chance of getting a high score (200+) than a straight ball does. Plus bowling a hook is a lot funner
- I would only recommend a straight ball to beginners, to get the basics down first, then eventually they should go on to a hook ball. Throwing a hook takes some people much longer to learn than others though, and if you only bowl 3-4 times a year, you probably don't care enough to start trying to develop a hook.
