Originally posted by: Whisper
Originally posted by: PingSpike
Originally posted by: Fingolfin269
There's no value in a bowflex when you can just go buy a power rack, barbell, and a ton of bb weights for a lot less. You can do every major compound exercise in a good power rack and you sort of have a 'spotter' to go with it.
Can you explain how a power rack works? Does it just have an extra set of hooks towards the bottom for when you fail and can't lift the barbell higher on bench?
What about for squats?
Sorry, I'm a newbie to all this stuff. But from everything I've read, you can't beat free weights for actual results.
I think it usually depends on which type of rack you get. Some have pegs that you can move up/down past the bottom of your motion for when you fail, like you mentioned. Others have a set of immovable pegs at regular distances, with the bar itself being attached to the rack. The bar has a set of hooks on either side so that if you rotate it, the hooks will catch the pegs.
I'd be willing to bet that most home benches have the former, as I've only seen the latter (the bar with the hooks) at regular gyms.
Honestly, I think the best advice was the post telling the OP to try out a gym membership for a year. It'll be cheaper than either free weights or a bowflex, and most likely better than both as well. A gym will have free weights AND machines, and more of either than any home gym ever could. The drawback is that you actually have to leave your house to workout; but that can be a benefit as well. I know that by the time I get to my gym, even if I don't feel like working out, I'd never leave early...otherwise all that driving would've been wasted.
Besides that, you always have a spot at a gym, which is something you will NEED for free weights. If you're doing exercises such as bench press without the need for a spot, then you aren't lifting heavy enough most likely. The last few sets where you need a tap or two are the ones that really help you to "feel the burn," so to speak, and the ones that shock your muscle into growth.
