Hellotalkie
why would it be more expensive to upgrade than any other computer. I have a fsp psu laying around + 9800gtx
cheap upgrade for me 😉
Originally posted by: OILFIELDTRASH
In no way is a dell or hp case better than what you can get in a aftermarket case even in a cheapie but remember the one I picked out is a name brand Thermaltake. Unless your talking about the high end alienware or cases of that ilk. I'm sure the case hes getting with it is one of the generic cheap plastic hp nightmares. More than likely the case hes getting is not even a micro atx mobo size but a size thats made specifically for Hp which basically means he can't use that same "great" :roll: HP case for future upgrading. They are in no way designed for good airflow. They are put together as cheaply as possible and might include 1 and if your lucky 2 120mm fans. Nowhere near what you could put in an aftermarket case. Oh yeah btw could you fit a aftermarket heatsink in that famous HP case. Why no mention that in my build he gets a blu ray player, a decent gaming gpu that can actually play games (a 4350 would be good for running vista aero but thats it), a more reliable ps, and upgradability which in the long run could save cash?
Originally posted by: cr2250
Times have changed and for some reason hp was much cheaper than building. Here are the specs. Did i do good?
No you didn't do good at all. You couldnt possibly be more wrong about the changing times. For the same $860 I can build a system which would absolutely decimate yours in gaming.
True, I wouldn't have the case, mouse/keyboard, windows, speakers, 2nd DVD drive, and all that junk software you are getting. Plus I would have 4gigs ram vs. your 6gigs.
However, I would have a 4870 1gig, and a 1TB hard drive! I'd rather run that sucker in a wooden box or with no box at all, then to use a crappy 4830 in a case. 😉
For only $40-50 more I would have the case, and for $20-30 more I'd have the keyboard and mouse.
Originally posted by: tcsenter
You still paid too much. All those other advantages may or may not make it worth it to you, but on its face, you paid a good $125.00+ more than you could have built an equivalent system for.
Edit: One other advantage to OEM systems is that they always (or almost always) standby and hibernate properly, because those specific components have been tested together before production. If the OEM finds a problem with standby or hibernate, they have the people to debug it and the direct contacts to get it solved in a BIOS, firmware, driver, or application update.
Only about 25% of the systems I build have properly working standby and hibernate. Its always something; one or more fans running at full speed, the system won't enter hibernate using PM timer but does when manually hibernating, the mouse or keyboard not waking the system even when configured in BIOS and using 5VSB+ power for the rear USB ports, peripherals not working properly after wake, always freaking something.
No.Originally posted by: cr2250
ok, build me a same exact setup, including software, accessories etc.
yeah...b/c you can't
You're right and I retract my statement. For some reason, I thought Core i7 920 was much cheaper than it actually is.Originally posted by: cr2250
Originally posted by: alyarb
you could've done it yourself for a little cheaper.
There's nothing wrong with sub-$200 X58 boards, provided you get 6 DIMM slots. Do you want a bunch of extra crap like free SLI bridges or eSATA bracket or a little device to hold your hand through an overclock? anand got a 920 to 4 GHz with that matx MSI board, which I'd like to see firsthand as well. At any rate, what motherboard do you think HP uses for their $800 i7 machines?
CPU $280
mobo $175
RAM $85
HDD $70
DVD $20
card reader? uh $10
GPU $30
PSU $55
thats $725 without even looking at any combos. which leaves 135 for a case or heatsink or something nice, but even if a DIY build did cost $100 more, the customizeability and overclockability are worth that. but yeah, those fancy USB 2.0 speakers closed that deal tight.
Originally posted by: JEDIYoda
Before you go on about heatsink....I have over 100 heatsinks in my collection and I know quite abit about heatsinks....so again you are wrong...
