Question Bottlenecked @ low speed w/new Internet
Motaro38
13
One problem is your PCIe port version and lane count. A PCIe version 2.0 port using 1 lane will only allow 500 MBps, which is only 4000 Gbps, which is less than the 5000 Gbps needed to support 2.5Gbps full-duplex (i.e. 2.5Gbps each direction). You are also need a decent CPU to handle the network traffic, the offload engine in windows for that card needs about 3-4x more CPU usage than most of the Intel 2.5Gbps cards (which is why the Intel cards run hotter and many have a heatsink+fan since it is offloading quite a bit more workload, and almost all those cards are PCIe version 3.0 so that they have the full bandwidth needed to support the actual 2.5Gbps speed).
Thanks for this post, Kell. Was concerned about this.
I plan to build a new PC, anyway, and all new MOBOs come with 2.5g+ ethernet ports in mobo so that, naturally, would solve problem.
Reactions: Shmee
mindless1
8,819
1,789
^ Or fiddle with network settings, even reinstall newest driver and then OS on the same system. It is not hardware limited to <=600Mb.
Motaro38
13
I think I've done all I can do. I did reinstall newest driver for network card, twice, I'm not reinstalling OS or installing dual partition/OS's, just not worth it imo and new pc will allow 2.5g bandwidth anyway. I really think its the hardware; mobo, or cpu...or whatever. It just wont allow more than 600-700mbit/sec. It was like 250mbit before, so its a big increase; definietly bi g enough for this pc. Do I wish I could see full 1800mbit/sec+ dl speeds? Of course...but I think I've run my course on this old workhorse. ;-)
DaaQ
2,031
1,444
Hello,
I have new 2,100 mbp/s internet, confirmed by tech. I have an older win 7 machine, so I upgraded network card to a 2.5g ethernet card (pci xpress x1) and bought new router (Flint2 w/OpenWRT) which has 2x 2.5g ports.
Ive worked for days now on this, and even though wifi works fine (phone gets 900Mbps+), wired only gets 600!!!
All cables involved are cat6.
Also checked and its newest ethernet card driver.
TP-Link 2.5GB PCIe Network Card (TX201)​
Not sure what is wrong, any help is appreciated!
Pics show 2.5gbps is confirmed, if these help at all.​
(Left Image) From Everest program
(Center Image) Pic of Comcast tech's phone, showing modem is getting more than 2,100mbit (2,408mbit)
(Right Image) Network Card properties showing 2.5gbps
View attachment 124310View attachment 124311View attachment 124312
Check properties here and make sure you are set to full duplex. Since it is a LAN 3 connection windows may have de prioritized it.
I had an instance of changing settings while drinking, and killed my download speeds, this was on Bulldozer. It was in that properties tab.
I took the easy way and just deleted the connection and let it rebuild it.
Just throwing it out there, maybe PCIE slots are the issue or IMO a windows issue.
